Register for the iXsystems Community to get an ad-free experience
Storj-node installation cert director location
dajimmy
Hi, I'm new to truenas scale and non-techie here.
I am trying to install Storj-node using Truechart. I had my indentify created using TrueNas shell, and the file is located at
root/.local/share/storj/identity
when I ran stoj-node app, in the log it says
Error: file or directory not found: open identity/identity.cert: no such file or directory
Where in the app setting can I adjust the file path to direct to my cert?
Thanks
danw
StorJ
Hey Dajimmy,
It looks like you may not have the identity generated yet for the Storj node. You can see detailed instructions for how to do that here
