Hi, I'm new to truenas scale and non-techie here.
I am trying to install Storj-node using Truechart. I had my indentify created using TrueNas shell, and the file is located at
root/.local/share/storj/identity
when I ran stoj-node app, in the log it says
Error: file or directory not found: open identity/identity.cert: no such file or directory
Where in the app setting can I adjust the file path to direct to my cert?
Thanks
Thanks
