SOLVED Storage=>View Disks is blank. Can't display volume.
Soypat
Hello community,
First off let me thank you all. I work on video production. We have a studio in Buenos Aires, Argentina. I've set up the FreeNAS 6 months a go (before we had just a basic homegroup) and it has been great! Our workflow is smooth and we did build it with hardware that we already had.
The issue.
Like a month a go the View Disks feature is not working. I do not get an output or error message. Is just blank. I can't check the capacity. Since I knew it was about
50% I chilled. But we keep on adding stuff. [Screenshots are on the footer of the post]
Yesterday I did freak out because one of mi colleagues added 200gb to the server.
And I've got an alert that the capacity did reach 85%.
I managed to check the capacity via Shell "df -h"
I quickly deleted the recycle been an I freed up 500GB. Now is on 70%
I searched for and answer. I found people with this similar issues but the solutions were not clear.
Also in this very case is different from all the results out there because I could display this info at first (the rest that I found could not display "View Disk" right from the initial set up).
I did not tried to "Scrub" I understand that it is a maintenance thing but I feel it may delete things if it isn't done properly. Is that right?
Besides, installing owncloud, activating recycled been and this kind of little stuff I did not mess that much with settings since my knowledge is limited on this field.
Apart from it I have this Alerts from a while a go:
Alerts:
OK: There is a new update available! Apply it in System -> Update tab.
CRITICAL: The volume NitidoServer (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
What do you guys think I should do next to fix this?
Thanks!
Edit: SOLVED by using firefox instead of chrome.
kdragon75
Please provide the output of the command zpool status
Soypat
Thanks for the reply.
I red somewere that it may be an issue with the browser. So I installed firefox and woalla. Everything is fine.
Sent from my SM-G930F using Tapatalk
kdragon75
This alert needs to be investigated. Your data may be at risk!
Soypat
Hey thanks!
I'll post the outpot of the command on monday. Cheers!
Soypat
[root@freenas ~]
This is the output that I've got.
# zpool status
  pool: NitidoServer
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
	   entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 3h52m with 1 errors on Sun Jul  1 03:52:40 2018
	   NAME											STATE	 READ WRITE CKSUM
	   NitidoServer									ONLINE	   0	 0	 0
		 mirror-0									  ONLINE	   0	 0	 0
		   gptid/2e81648a-4033-11e8-a741-f46d04997062  ONLINE	   0	 0	 0
		   gptid/2efd93a8-4033-11e8-a741-f46d04997062  ONLINE	   0	 0	 0
errors: 1 data errors, use '-v' for a list
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Wed Jun 20 03:45:40 2018
	   freenas-boot								  ONLINE	   0	 0	 0
		 gptid/611d644a-3c1a-11e8-bb26-f46d04997062  ONLINE	   0	 0	 0
errors: No known data errors
[root@freenas ~]#
Thanks!
Diego.
You should do as suggested by the first run of the command and run it again with -v to see which file is potentially lost or corrupt.
