tbaror
- Mar 20, 2013
Hello All,
I have following system spec below , that used for almost 3years already with latest version :FreeNAS-11.2-U5 (Build Date: Jun 24, 2019 18:41) , with auto-tune enabled.
Storage mostly used for XCP-NG vm guest spin-on on NFS SR(v4) dataset, and some dev team smb share ,All was working well for recently issues started to appear around 4 month ago ,but recent days impossible to work with the VM's until got to situation that system is unusable , vm's get stack and not responding ,same for smb.
To get to conclusion that the storage itself is in fault i did following tests:
Network testing: using iperf3 testing from xcp host to storage ,results shows figures that reflects 10Gbit network shown below
Storage testing(Intenal) : i run following command :
Results actually shows around 120Mbytes/s ,this is really poor results I Remember when storage where new , i did same tests where more than 10 faster
System events
the only events i can see is as follows
Given all description and the fact the system not reporting any issues , i really don't know where to go from here , any idea
Please advice
Thanks
SYSTEM SPEC
The Dataset settings for the vm dataset i used following , the storage structure is as following
Disk pool
Shows healthy with 4x RZ2x 9 disks ,model Vendor:SEAGATE Product:ST10000NM0096 Revision:E001
Nvme drives
LOG drive mirror 2x INTEL SSDPE2ME800G4
CACHE drive stip 2x INTEL SSDPE2ME800G4
System oveall health
In addition i see inside server IPMI that all hardware component are healthy including NVME drives
Chassis model and System
SSG-6048R-E1CR60L
CPU 2xProcessor:Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
Memory:512Gbytes
Network 4x10G nic
[11:54 vnxe03-r15 ~]# iperf3 -c 10.100.1.10 Connecting to host 10.100.1.10, port 5201 [ 4] local 10.100.1.52 port 56708 connected to 10.100.1.10 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 1008 MBytes 8.46 Gbits/sec 0 567 KBytes [ 4] 1.00-2.00 sec 1.09 GBytes 9.39 Gbits/sec 0 628 KBytes [ 4] 2.00-3.00 sec 1.09 GBytes 9.36 Gbits/sec 0 782 KBytes [ 4] 3.00-4.00 sec 1009 MBytes 8.46 Gbits/sec 0 822 KBytes [ 4] 4.00-5.00 sec 982 MBytes 8.24 Gbits/sec 0 895 KBytes [ 4] 5.00-6.00 sec 1.05 GBytes 9.04 Gbits/sec 0 895 KBytes [ 4] 6.00-7.00 sec 1019 MBytes 8.54 Gbits/sec 0 895 KBytes [ 4] 7.00-8.00 sec 941 MBytes 7.89 Gbits/sec 0 895 KBytes [ 4] 8.00-9.00 sec 1011 MBytes 8.48 Gbits/sec 0 895 KBytes [ 4] 9.00-10.00 sec 949 MBytes 7.95 Gbits/sec 0 895 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 9.99 GBytes 8.58 Gbits/sec 0 sender [ 4] 0.00-10.00 sec 9.99 GBytes 8.58 Gbits/sec receiver
dd if=/dev/zero of=/mnt/po01/vm_datastoretest.dat bs=2048k count=10000 10000+0 records in 10000+0 records out 20971520000 bytes transferred in 205.693829 secs (101955028 bytes/sec)
System events
nfsrv_cache_session: no session
Please advice
Thanks
SYSTEM SPEC
set sync=disabled for just that dataset
Disk pool
Nvme drives
SSG-6048R-E1CR60L
Memory:512Gbytes
Network 4x10G nic
