State: FAULTED - Help Please...
Pedro Uva
Hello guys. I really need your help. I believe I lost all my data. I need to know if it is possible to recover my data.
I am Brazilian, I do not write or speak fluent English, I am using a translator.
I have a FreeNAS running in a virtual environment with Proxmox. I decided to remove it from the environment. I put the external hard drive that was plugged into the FreeNAS on a Linux Ubuntu server, but gave the wrong command. It was to mount the external hard drive as ZFS, and I created a new pool ...
The output of the commands are these:
[root@freenas] /# gpart list
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 10485759
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: ada0s1
Mediasize: 988291584 (942M)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 32256
Mode: r1w0e1
attrib: active
rawtype: 165
length: 988291584
offset: 32256
type: freebsd
index: 1
end: 1930319
start: 63
2. Name: ada0s2
Sectorsize: 512
Stripesize: 0
Stripeoffset: 988356096
Mode: r0w0e0
rawtype: 165
length: 988291584
offset: 988356096
type: freebsd
index: 2
end: 3860639
start: 1930383
3. Name: ada0s3
Mediasize: 1548288 (1.5M)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 1976647680
Mode: r0w0e0
rawtype: 165
length: 1548288
offset: 1976647680
type: freebsd
index: 3
end: 3863663
start: 3860640
4. Name: ada0s4
Mediasize: 21159936 (20M)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 1978195968
Mode: r1w1e2
rawtype: 165
length: 21159936
offset: 1978195968
type: freebsd
index: 4
end: 3904991
start: 3863664
Consumers:
1. Name: ada0
Mediasize: 5368709120 (5.0G)
Sectorsize: 512
Mode: r2w1e4
Geom name: ada0s1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: ada0s1a
Mediasize: 988283392 (942M)
Sectorsize: 512
Stripesize: 0
Stripeoffset: 40448
Mode: r1w0e1
rawtype: 0
length: 988283392
offset: 8192
type: !0
index: 1
end: 1930256
start: 16
Consumers:
1. Name: ada0s1
Sectorsize: 512
Stripesize: 0
Stripeoffset: 32256
Mode: r1w0e1
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 488378639
first: 6
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
Mediasize: 2000322297856 (1.8T)
Sectorsize: 4096
Stripesize: 0
Stripeoffset: 8388608
Mode: r0w0e0
rawuuid: 28c75617-625a-2340-a63a-80b978c0d508
rawtype: 6a898cc3-1dd2-11b2-99a6-080020736631
label: zfs
length: 2000322297856
offset: 8388608
type: !6a898cc3-1dd2-11b2-99a6-080020736631
index: 1
end: 488361983
start: 2048
2. Name: da0p9
Mediasize: 67108864 (64M)
Sectorsize: 4096
Stripesize: 0
Stripeoffset: 3170893824
Mode: r0w0e0
rawuuid: 9b131a90-9bb4-7944-a229-f1ce28b53307
rawtype: 6a945a3b-1dd2-11b2-99a6-080020736631
label: (null)
length: 67108864
offset: 2000330686464
type: !6a945a3b-1dd2-11b2-99a6-080020736631
index: 9
end: 488378367
start: 488361984
Consumers:
1. Name: da0
Mediasize: 2000398929920 (1.8T)
Sectorsize: 4096
Mode: r0w0e0
[root@freenas] /#
[root@freenas] /# gpart show
=> 63 10485697 ada0 MBR (5.0G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 6580768 - free - (3.1G)
=> 0 1930257 ada0s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M)
=> 6 488378634 da0 GPT (1.8T)
6 2042 - free - (8M)
2048 488359936 1 !6a898cc3-1dd2-11b2-99a6-080020736631 (1.8T)
488361984 16384 9 !6a945a3b-1dd2-11b2-99a6-080020736631 (64M)
488378368 272 - free - (1.1M)
[root@freenas] /#
[root@freenas] /# zpool import
pool: stg2tb
state: FAULTED
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
The pool may be active on another system, but can be imported using
the '-f' flag.
see: http://illumos.org/msg/ZFS-8000-5E
stg2tb FAULTED corrupted data
16792522702376110269 UNAVAIL corrupted data
pool: pool
state: UNAVAIL
status: The pool was last accessed by another system.
see: http://illumos.org/msg/ZFS-8000-EY
pool UNAVAIL unsupported feature(s)
da0p1 ONLINE
[root@freenas] /#
[root@freenas] /# smartctl -a -q noserial /dev/da0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p15 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST2000DM001-1E6164
Firmware Version: SC48
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Jul 8 00:50:45 2015 BRT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
was never started.
been run.
data collection: ( 584) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 236) minutes.
Conveyance self-test routine
SCT capabilities: (0x3081) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 59972472
3 Spin_Up_Time 0x0003 096 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 89
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 056 051 030 Pre-fail Always - 575580337002
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 5202
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 79
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 088 088 000 Old_age Always - 12
190 Airflow_Temperature_Cel 0x0022 062 042 045 Old_age Always In_the_past 38 (1 119 41 35 0)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 68
193 Load_Cycle_Count 0x0032 056 056 000 Old_age Always - 88544
194 Temperature_Celsius 0x0022 038 058 000 Old_age Always - 38 (0 18 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 4195h+40m+53.661s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6040122680
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 9732618856
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] /#
[root@freenas] /# camcontrol devlist
<QEMU HARDDISK 2.1.0> at scbus2 target 0 lun 0 (pass0,ada0)
<Seagate Expansion Desk 0712> at scbus9 target 0 lun 0 (pass1,da0)
[root@freenas] /#
[root@freenas] /# glabel status
Name Status Components
ufs/FreeNASs3 N/A ada0s3
ufs/FreeNASs4 N/A ada0s4
ufs/FreeNASs1a N/A ada0s1a
gpt/zfs N/A da0p1
gptid/28c75617-625a-2340-a63a-80b978c0d508 N/A da0p1
gptid/9b131a90-9bb4-7944-a229-f1ce28b53307 N/A da0p9
[root@freenas] /#
There is a possibility I recover my data on the external hard drive?
The volume name was stg2tb.
I greatly appreciate the help of anyone who can help. The pictures of my little children were there ...
Thank you
Pedro.
I know you PMed me for help. But I'm sorry but I don't get involved with discussions that involved virtualized FreeNAS installations anymore. The community has warned everyone of the risks, and choosing to go through with it is your own personal choice. Sorry, but that's all I have to say about this.
