Ok just got everything up and running... got good transfer rates 50-65 MB/sec , figured out to WOL and almost got Rsync working. Now here is my question.. Im trying to tweak the power down as much as possible. Using a Kill-a-Watt metter I got this thing to idle at 17 watts (loaded it with Win 7 before freenas) but when I use FreeNAS it will only go as low as 22 -24 watts when idle. Here is what I have done so far .....set HDD Standby for 120, APM at 128, I enable then disabled SMART(same either way power wise) and just left Acoustic lvl disabled. What else can I do to try an cut the idle power down.
Oh and this is just storage for an HTPC and a weekly backup of my main PC.
specs.....
ASROCK E350M1 {CPU fan lvl 1 in BIOS}
Pareema 4GB (2 x 2GB)
Intel EXPI9301CTBLK NIC
4 - WD20EARS 2TB HDD
picoPSU-150-XT PowerSupply
1 - Noctua NF-R8-1800 {lvl 1 manual speed control in BIOS}
specs.....
