I bought a used S3500 Intel SSD from ebay, and the drives shows error in SMART. Is this error serious and worth returning the drive?
# smartctl -a /dev/da15 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-RELEASE-p10 amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SSDSC2BB480G4I 00AJ331 00AJ334IBM LU WWN Device Id: 5 5cd2e4 04b4ad5b4 Firmware Version: D201NB34 User Capacity: 480,103,981,056 bytes [480 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri May 18 17:53:59 2018 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x79) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 2) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 130 130 039 Pre-fail Always - 148 5 Reallocated_Sector_Ct 0x0033 097 097 001 Pre-fail Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 7 13 Read_Soft_Error_Rate 0x001e 130 100 000 Old_age Always - 148 100 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2 170 Unknown_Attribute 0x0033 100 100 010 Pre-fail Always - 5971 171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 173 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 1 174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 4 177 Wear_Leveling_Count 0x0032 100 100 --- Old_age Always - 1 184 End-to-End_Error 0x0033 100 100 000 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 56 190 Airflow_Temperature_Cel 0x0026 068 059 029 Old_age Always - 32 (Min/Max 23/35) 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 4 194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 21 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 471663 196 Reallocated_Event_Count 0x0033 100 100 010 Pre-fail Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 112 231 Temperature_Celsius 0x0033 100 100 010 Pre-fail Always - 0 232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 128898768 233 Media_Wearout_Indicator 0x0033 100 100 001 Pre-fail Always - 0 235 Unknown_Attribute 0x0033 100 100 001 Pre-fail Always - 659 237 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 4294967955 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 256 242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 640 SMART Error Log Version: 1 ATA Error Count: 38 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 38 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 12 01 00 00 00 00 00 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:11:11.102 IDENTIFY DEVICE ec 00 00 00 00 00 00 00 00:11:11.100 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:11:10.852 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:11:10.852 SET FEATURES [Enable read look-ahead] ef 03 46 00 00 00 00 00 00:11:10.852 SET FEATURES [Set transfer mode] Error 37 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 12 01 00 00 00 00 00 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:09:36.074 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:09:35.198 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:09:35.197 SET FEATURES [Enable read look-ahead] ef 03 46 00 00 00 00 00 00:09:35.197 SET FEATURES [Set transfer mode] ef 03 0c 00 00 00 00 00 00:09:35.197 SET FEATURES [Set transfer mode] Error 36 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 12 01 00 00 00 00 00 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:09:32.319 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:08:48.267 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:08:48.267 SET FEATURES [Enable read look-ahead] ef 03 46 00 00 00 00 00 00:08:48.267 SET FEATURES [Set transfer mode] ef 03 0c 00 00 00 00 00 00:08:48.267 SET FEATURES [Set transfer mode] Error 35 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 12 01 00 00 00 00 00 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:08:41.726 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:08:40.529 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:08:40.529 SET FEATURES [Enable read look-ahead] ef 03 46 00 00 00 00 00 00:08:40.529 SET FEATURES [Set transfer mode] ef 03 0c 00 00 00 00 00 00:08:40.529 SET FEATURES [Set transfer mode] Error 34 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 12 01 00 00 00 00 00 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:08:37.575 IDENTIFY DEVICE b0 d0 00 00 4f c2 00 00 00:08:36.582 SMART READ DATA ec 00 00 00 00 00 00 00 00:08:36.582 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:08:36.547 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:08:36.547 SET FEATURES [Enable read look-ahead] SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 00 00 00:08:37.575 IDENTIFY DEVICE b0 d0 00 00 4f c2 00 00 00:08:36.582 SMART READ DATA ec 00 00 00 00 00 00 00 00:08:36.582 IDENTIFY DEVICE ef 02 00 00 00 00 00 00 00:08:36.547 SET FEATURES [Enable write cache] ef aa 00 00 00 00 00 00 00:08:36.547 SET FEATURES [Enable read look-ahead] SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
