Hi All,
I have finally started to make my NAS Server and before I got a chance to set the pool up FreeNAS gave me a warning telling me that one of my drives had issues.
When I checked the issues there are around 3543 Uncorrectable Sectors / Pending Sectors does this mean that they are all marked as bad?
What makes me question this that if I read the SMART info below the errors were detected when the drive was 77 hours old it is now nearly 4000 hours old and not had any errors since then or issues. The drive was being used as Media Storage and was nearly at capacity most of the time when it was in my old server.
Now I ran the extended test on SMART and it says it is going to take 15 hours to complete which I guess is fair enough as its a big drive however what is concerning me more is that 5 hours in and it still says there is 90% remaining and the progress hasnt increased at all.. Is this normal? The disk is idle as I havent created a pool yet so I know it is not usage that is causing the extra delay. If there is a read error does the SMART test just fail or will it run for ever more?
If it makes any difference the drive is a Seagate SMR Drive,.
I have attached my hardware and the extended results below:
Hardware:
FreeNAS 9.10 U2
ESXi Whitebox running on Asus P87QM-E Motherboard
LSI 9211-8i Running in pass through
16GB DDR3 RAM
Not Set Up A Pool yet
Hardware:
FreeNAS 9.10 U2
16GB DDR3 RAM
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 249) Self-test routine in progress... 90% of test remaining. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off supp ort. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 932) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x30a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 231011232 3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 236 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 1 7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 4436110005 9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3852 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 214 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 089 089 000 Old_age Always - 11 188 Command_Timeout 0x0032 100 098 000 Old_age Always - 8590065666 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 060 052 045 Old_age Always - 40 (Min/Max 37/40) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 323 193 Load_Cycle_Count 0x0032 099 099 000 Old_age Always - 2965 194 Temperature_Celsius 0x0022 040 048 000 Old_age Always - 40 (0 21 0 0 0) 195 Hardware_ECC_Recovered 0x001a 119 099 000 Old_age Always - 231011232 197 Current_Pending_Sector 0x0012 090 090 000 Old_age Always - 3543 198 Offline_Uncorrectable 0x0010 090 090 000 Old_age Offline - 3543 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3795 (49 124 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 39614232638 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 34401743240 SMART Error Log Version: 1 ATA Error Count: 11 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 11 occurred at disk power-on lifetime: 77 hours (3 days + 5 hours) When the command that caused the error occurred, the device was active or idle . After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 01 ff ff ff 4f 00 00:39:52.100 READ FPDMA QUEUED 60 00 01 ff ff ff 4f 00 00:39:52.100 READ FPDMA QUEUED 60 00 01 ff ff ff 4f 00 00:39:52.099 READ FPDMA QUEUED 60 00 01 ff ff ff 4f 00 00:39:52.099 READ FPDMA QUEUED 60 00 01 ff ff ff 4f 00 00:39:52.099 READ FPDMA QUEUED Error 10 occurred at disk power-on lifetime: 77 hours (3 days + 5 hours) When the command that caused the error occurred, the device was active or idle . After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 3f ff ff ff 4f 00 00:39:49.294 READ FPDMA QUEUED 60 00 3f ff ff ff 4f 00 00:39:49.293 READ FPDMA QUEUED 60 00 3f ff ff ff 4f 00 00:39:49.293 READ FPDMA QUEUED 60 00 3f ff ff ff 4f 00 00:39:49.293 READ FPDMA QUEUED 60 00 3f ff ff ff 4f 00 00:39:49.292 READ FPDMA QUEUED Error 9 occurred at disk power-on lifetime: 75 hours (3 days + 3 hours) When the command that caused the error occurred, the device was active or idle . After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 08 ff ff ff ef 00 00:07:25.359 READ DMA EXT ef 10 02 00 00 00 a0 00 00:07:25.358 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 e0 00 00:07:25.358 READ NATIVE MAX ADDRESS EXT [OBS-AC S-3] ec 00 00 00 00 00 a0 00 00:07:25.357 IDENTIFY DEVICE ef 03 46 00 00 00 a0 00 00:07:25.357 SET FEATURES [Set transfer mode] Error 8 occurred at disk power-on lifetime: 75 hours (3 days + 3 hours) When the command that caused the error occurred, the device was active or idle . After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 08 ff ff ff ef 00 00:07:22.576 READ DMA EXT ef 10 02 00 00 00 a0 00 00:07:22.575 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 e0 00 00:07:22.575 READ NATIVE MAX ADDRESS EXT [OBS-AC S-3] ec 00 00 00 00 00 a0 00 00:07:22.574 IDENTIFY DEVICE ef 03 46 00 00 00 a0 00 00:07:22.574 SET FEATURES [Set transfer mode] Error 7 occurred at disk power-on lifetime: 75 hours (3 days + 3 hours) When the command that caused the error occurred, the device was active or idle . After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 08 ff ff ff ef 00 00:07:19.752 READ DMA EXT 25 00 08 ff ff ff ef 00 00:07:19.751 READ DMA EXT 25 00 08 ff ff ff ef 00 00:07:19.751 READ DMA EXT 25 00 08 ff ff ff ef 00 00:07:19.751 READ DMA EXT 25 00 08 ff ff ff ef 00 00:07:19.750 READ DMA EXT SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error # 1 Extended offline Self-test routine in progress 90% 3852 - # 2 Short offline Completed: read failure 90% 78 - # 3 Short offline Completed: read failure 90% 78 - # 4 Short offline Completed: read failure 90% 78 - # 5 Short offline Completed: read failure 90% 77 - # 6 Short offline Completed: read failure 10% 76 - # 7 Extended offline Completed: read failure 90% 76 - # 8 Short offline Completed: read failure 90% 76 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas] ~#
