Spotlight support in afp
slowfranklin
Unfortunately FreeBSD's Gnome Tracker port is _way_ too old: version 0.6.95, while the latest is 0.16.2 afair.
D
dlavigne
Guest
Once the ports are updated, please create a feature enhancement at bugs.freenas.org and post the issue number here.
tmueko
I did a first test: Installed sysutils/tracker from Ports in a Jail (just type "pkg install sysutils/tracker"); there will be a lot of dependencies.
Then I configured "trackerd" an started it. Its all locking fine.
tmueko
Just asked the Port-Maintainer tu upgrade tracker to 1.2.3 no I'm waiting for pkg-file as build from source fails.
tmueko
I could install "tracker" in a Portjail an start indexing the hd.
But this will not run as a plugin as it need dbus for communication. We will have to configure everything in the jail including netatalk!
And this tracker-thing need a hundred additional packages, I don't thing the freenas-guys will integrate it in base distribution.
Eric Batte
I'm curious if this version of samba will be included in Freenas 10. Can anyone confirm?
