elvisimprsntr
- Jun 2, 2019
BACKGROUND
I run both CORE and SCALE behind pfSense and don't expose either directly to the internet. Obviously, Spectre and Meltdown come with performance hits. I was hoping that there was an easy way to disable mitigations to assess the performance impact. On Linux, there is a mitigations=off kernel option that will disable all mitigations rather than having to specify all of them individually.
forum.proxmox.com
QUESTIONS
1. Is there an equivalent for CORE (FreeBSD) and where to configure it to persist on updates?
2. Since SCALE is based on Debian, I assume it supports the mitigations=off kernel option, but where can it be configured to persist on updates?
Disable Spectre Meltdown Mitigations
BACKGROUND I'm running a homelab. I wanted to test the performance hit of all the mitigations including SMT, but the method I found does not seem to be working QUESTION What is the correct method? VERSION PVE 7.2-7 5.15.39-1-pve METHOD USED 1. nano /etc/default/grub to...
QUESTIONS
