Sonarr and Radarr won't work
BlazeStar
Using TrueNAS-12.0-U2.1
I did a fresh install of the following plugins:
  • Radarr
  • Sonarr
I did not mess around with any advanced settings.
The only choice I had was NAT vs DHCP.
I chose DHCP for both.
The install completes successfully.
When I try to access their IP or click on MANAGE, they are unreachable.
Any idea why?
It looks like those plugins are not delivering a working service at this point.
You can build a manual jail using the resources if you want those services before fixed plugins are delivered.
BlazeStar
Is there any way to have an estimation of when those plugins will be fixed?
Danpomeroy
Danpomeroy
I don't know if this will help but I just followed this guide and Sonarr is installed and working for me. I haven't configured it or anything but working on that now.
https://www.reddit.com/r/sonarr/comments/g9cr1r/how_to_install_sonarr_v3_on_freenas/
Seems trivial to copy this idea for radarr.
just followed the same steps and got Radarr to work.
  • replace Sonarr with Radarr
  • Change the IP address
  • Go in to Radarr Status and install the latest version
  • update Mono
done
radarr port is 7878
Elo
I instaled them in two new Jails along with SABNZBD in a third. It all worked OK after the usual tuning...Please be very particulate with permissions as this is the most usual reasons for Sonarr,Radarr not to work. This is a good guide:
Install and conf Sonarr , Radarr ++++
