As far as I know TrueNAS SCALE should not be used in productive environments so far, but what are the reasons?
I assume the underlying ZFS stuff is in a mature state. Does the system itself has some possible stability issues? Is it about the HBA drivers which are not as mature as on FreeBSD? Could this risk the integrity of the stored data?
What problems are expected with TrueNAS SCALE in this early software stage?
Currently, I'm thinking about to use SCALE (mainly because of the Linux-based virtualization features compared to CORE) for my private server to store all my data. Meaning, the data integrity has to be ensured, but if in worst case the system has a downtime of 1-2 days, it is not a problem. Would SCALE be an option for me?
Is the configuration/maintenance of SCALE much more complex compared to CORE?
Is it possible to use a configuration backup of SCALE in CORE and vice versa? Are the backup format (Config DB?) compatible with each other?
And last, but not least, do CORE and SCALE use the same OpenZFS "versions", so that pools could be migrated without any ZFS feature issues (assuming both systems are up-to-date) between both systems?
