[solved] traefik gives 404 to truecommand
uberthoth
After following the excellent traefik tutorial
Traefik now has port 80 and 443.
Recently I thought I would try out truecommand, but it gives this error:
failed to WebSocket dial: expected handshake response status code 101 but got 404
I assume that truecommand is connecting to either 443 or 80 and traefik is giving back the 404.
How do I get truecommand to contact 444 or 81 (heavy preference to 444).
uberthoth
For some reason when you edit a server you cannot just append :444
But if you delete the server and recreate it, truecommand does allow you to specify the port like that.
solved.
