pewterspoon
- Dec 30, 2022
I recently installed Traefik via TrueCharts. In doing so, I change the TrueNAS web interface HTTP port to 81 and the HTTPS port to 444, as to not interfere with 80 and 443 being used by Traefik. After realizing I now needed to type "http://192.168.3.164:444/ui/dashboard" into the address bar instead of just "http://192.168.3.164/ui/dashboard" as I was used to doing, I decided to change the web interface ports back to 80 and 443.
The problem now is that I cannot seem to connect to the web interface at all. Typing "http://192.168.3.164/ui/dashboard" or "https://192.168.3.164:443/ui/dashboard" into the address bar indefinitely shows the "Connecting to TrueNAS..." screen.
I've tried plugging a monitor/keyboard directly into my machine to show the console setup. This even shows that the ports are set correctly:
but trying to connect to either of these addresses causes the CLI to show a message like:
Any idea how to fix this?
The web user interface is at: http://192.168.3.164:80 https://192.168.3.164:443
[2038531.364636] IPVS: rr: TCP 192.168.3.164:80 - no destination available [2038608.423413] IPVS: rr: TCP 192.168.3.164:443 - no destination available
