The_Hitman
- May 28, 2018
I have got all plugins to work so far except for Deluge. I create a mount point between an unused folder within my dataset and the Downloads folder it has by default in the UI. The same thing works within Plex but in Deluge, if I add a torrent, it starts for like a second at 50 kb/s then goes down to 0, signaling that it's only using the cache and not writing anywhere.
However the interface correctly states the free space of the dataset. So it "can see" it but it can't write to it.
What other settings do I need to configure for the jail? User is just like in the other plugins "root", and everything works fine with them, but do I need to select the user owning the dataset?
[EDIT: Also, out of curiosity, qBittorrent doesn't work at all, not even accessible. Is that a known issue?]
Screenshots below:
(removed the other two, they were showing my ddns address, oops)
Screenshots below:
