smbd crashes again and again an 13-U3 + Samba internal package
I think I will go back to v12, no one maschine can create bnackup on v 13 In messages I see error like this here
smbd 32894 - - [2022/12/28 11:29:20.661987, 0] ../../lib/util/fault.c:172(smb_panic_log) smbd 32894 - - =============================================================== smbd 32894 - - [2022/12/28 11:29:20.662234, 0] ../../lib/util/fault.c:176(smb_panic_log) smbd 32894 - - INTERNAL ERROR: unable to get back to old directory smbd 32894 - - in pid 32894 (4.15.13) smbd 32894 - - [2022/12/28 11:29:20.662322, 0] ../../lib/util/fault.c:181(smb_panic_log) smbd 32894 - - If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.g smbd 32894 - - [2022/12/28 11:29:20.662384, 0] ../../lib/util/fault.c:182(smb_panic_log) smbd 32894 - - =============================================================== smbd 32894 - - [2022/12/28 11:29:20.662442, 0] ../../lib/util/fault.c:184(smb_panic_log) smbd 32894 - - PANIC (pid 32894): unable to get back to old directory smbd 32894 - - in 4.15.13 smbd 32894 - - [2022/12/28 11:29:20.664783, 0] ../../lib/util/fault.c:288(log_stack_trace) smbd 32894 - - BACKTRACE: 28 stack frames: smbd 32894 - - #0 0x8014b3177 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0 smbd 32894 - - #1 0x8014b3251 <smb_panic+0x11> at /usr/local/lib/samba4/libsamba-util.so.0 smbd 32894 - - #2 0x801b1ed49 <fd_openat+0xce9> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #3 0x801b1e0d7 <fd_openat+0x77> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #4 0x801ac52d1 <openat_pathref_fsp+0x231> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #5 0x8166ef45f <samba_init_module+0x9e5f> at /usr/local/lib/shared-modules/vfs/fruit.so smbd 32894 - - #6 0x8166eed99 <samba_init_module+0x9799> at /usr/local/lib/shared-modules/vfs/fruit.so smbd 32894 - - #7 0x8166e9f4b <samba_init_module+0x494b> at /usr/local/lib/shared-modules/vfs/fruit.so smbd 32894 - - #8 0x801b48136 <make_connection_smb2+0xe76> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #9 0x801b4731a <make_connection_smb2+0x5a> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #10 0x801b5f40d <smbd_smb2_request_process_tcon+0x65d> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #11 0x801b557ff <smbd_smb2_request_dispatch+0x134f> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #12 0x801b5a3e2 <smbd_smb2_process_negprot+0x24f2> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #13 0x8029ef57d <tevent_common_invoke_fd_handler+0x9d> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #14 0x8029f598d <tevent_ctx_get_iocb+0x8ed> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #15 0x8029f41d0 <tevent_signal_get_tag+0x230> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #16 0x8029ee591 <_tevent_loop_once+0xe1> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #17 0x8029ee7f2 <tevent_common_loop_wait+0x32> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #18 0x8029f4250 <tevent_signal_get_tag+0x2b0> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #19 0x801b436a3 <smbd_process+0x7b3> at /usr/local/lib/samba4/private/libsmbd-base-samba4.so smbd 32894 - - #20 0x1032373 <main+0x44b3> at /usr/local/sbin/smbd smbd 32894 - - #21 0x8029ef57d <tevent_common_invoke_fd_handler+0x9d> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #22 0x8029f598d <tevent_ctx_get_iocb+0x8ed> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #23 0x8029f41d0 <tevent_signal_get_tag+0x230> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #24 0x8029ee591 <_tevent_loop_once+0xe1> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #25 0x8029ee7f2 <tevent_common_loop_wait+0x32> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #26 0x8029f4250 <tevent_signal_get_tag+0x2b0> at /usr/local/lib/samba4/private/libtevent.so.0 smbd 32894 - - #27 0x10308df <main+0x2a1f> at /usr/local/sbin/smbd smbd 32894 - - [2022/12/28 11:29:20.665703, 0] ../../source3/lib/dumpcore.c:315(dump_core) smbd 32894 - - dumping core in /var/db/system/cores smbd 32894 - - kernel: pid 32894 (smbd), jid 0, uid 0: exited on signal 6 (core dumped)
