LaserAllan
- Mar 25, 2017
Hi there folks!
So the last couple of days I have been trying to get Veeam backup & replication 9.5 software to play nice with a CIFS share that I have added as a backup repository. However getting that to play nicely seems to be much harder than expected. After a lot of troubleshooting this is what I have found so far:
/var/log/samba4/log.smbd
Dmesg
The auxillary paramters I have set in SMB is the following:
I am kinda lost what to try at this point. I have tried NFS with similar results.
Build FreeNAS-11.1-U1
Motherboard: ASRock C2758D4
CPU: Intel Atom C2758
32 gig ECC RAM
Boot devices are dual USB sticks Sandisk Ultrafit
[2018/02/12 00:41:44.047613, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../lib/dbwrap/dbwrap.c:166(dbwrap_check_lock_order) Lock order violation: Trying /var/db/samba4/file_ntacls.tdb at 1 while /var/lock/locking.tdb at 1 is locked [2018/02/12 00:41:44.047693, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../lib/dbwrap/dbwrap.c:115(debug_lock_order) lock order: 1:/var/lock/locking.tdb 2:<none> 3:<none> [2018/02/12 00:41:44.047787, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/lib/util.c:804(smb_panic_s3) PANIC (pid 45136): invalid lock_order [2018/02/12 00:41:44.051424, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/lib/util.c:915(log_stack_trace) BACKTRACE: 34 stack frames: #0 0x80326f2fe <log_stack_trace+0x1e> at /usr/local/lib/libsmbconf.so.0 #1 0x80326f0f8 <smb_panic_s3+0x98> at /usr/local/lib/libsmbconf.so.0 #2 0x800c9e597 <smb_panic+0x27> at /usr/local/lib/libsamba-util.so.0 #3 0x8075d63af <dbwrap_name+0x27f> at /usr/local/lib/samba/libdbwrap-samba4.so #4 0x8075d5162 <dbwrap_fetch_locked+0x82> at /usr/local/lib/samba/libdbwrap-samba4.so #5 0x8075d5114 <dbwrap_fetch_locked+0x34> at /usr/local/lib/samba/libdbwrap-samba4.so #6 0x81b87e291 <samba_init_module+0x2921> at /usr/local/lib/shared-modules/vfs/acl_tdb.so #7 0x81b87db38 <samba_init_module+0x21c8> at /usr/local/lib/shared-modules/vfs/acl_tdb.so #8 0x81b87c482 <samba_init_module+0xb12> at /usr/local/lib/shared-modules/vfs/acl_tdb.so #9 0x801232a7f <smb_vfs_call_unlink+0x4f> at /usr/local/lib/samba/libsmbd-base-samba4.so #10 0x8012267e0 <msg_close_file+0x1b50> at /usr/local/lib/samba/libsmbd-base-samba4.so #11 0x801224a7f <close_file+0x11df> at /usr/local/lib/samba/libsmbd-base-samba4.so #12 0x80122392e <close_file+0x8e> at /usr/local/lib/samba/libsmbd-base-samba4.so #13 0x80128935f <smbd_smb2_request_process_close+0x12df> at /usr/local/lib/samba/libsmbd-base-samba4.so #14 0x8012884c5 <smbd_smb2_request_process_close+0x445> at /usr/local/lib/samba/libsmbd-base-samba4.so #15 0x80128827f <smbd_smb2_request_process_close+0x1ff> at /usr/local/lib/samba/libsmbd-base-samba4.so #16 0x80126eb5f <smbd_smb2_request_dispatch+0x136f> at /usr/local/lib/samba/libsmbd-base-samba4.so #17 0x801276bd2 <smbd_smb2_process_negprot+0x4002> at /usr/local/lib/samba/libsmbd-base-samba4.so #18 0x801276296 <smbd_smb2_process_negprot+0x36c6> at /usr/local/lib/samba/libsmbd-base-samba4.so #19 0x804c2124c <tevent_req_set_cleanup_fn+0x15cc> at /usr/local/lib/libtevent.so.0 #20 0x804c20696 <tevent_req_set_cleanup_fn+0xa16> at /usr/local/lib/libtevent.so.0 #21 0x804c1cc18 <_tevent_loop_once+0x118> at /usr/local/lib/libtevent.so.0 #22 0x804c20738 <tevent_req_set_cleanup_fn+0xab8> at /usr/local/lib/libtevent.so.0 #23 0x804c1d0d0 <_tevent_loop_wait+0x30> at /usr/local/lib/libtevent.so.0 #24 0x8012503ad <smbd_process+0xe9d> at /usr/local/lib/samba/libsmbd-base-samba4.so #25 0x41305e <main+0x7a7e> at /usr/local/sbin/smbd #26 0x804c2124c <tevent_req_set_cleanup_fn+0x15cc> at /usr/local/lib/libtevent.so.0 #27 0x804c20696 <tevent_req_set_cleanup_fn+0xa16> at /usr/local/lib/libtevent.so.0 #28 0x804c1cc18 <_tevent_loop_once+0x118> at /usr/local/lib/libtevent.so.0 #29 0x804c20738 <tevent_req_set_cleanup_fn+0xab8> at /usr/local/lib/libtevent.so.0 #30 0x804c1d0d0 <_tevent_loop_wait+0x30> at /usr/local/lib/libtevent.so.0 #31 0x40fcd8 <main+0x46f8> at /usr/local/sbin/smbd #32 0x40d77f <main+0x219f> at /usr/local/sbin/smbd #33 0x40703f <_start+0x17f> at /usr/local/sbin/smbd [2018/02/12 00:41:44.053031, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/lib/util.c:816(smb_panic_s3) smb_panic(): calling panic action [/usr/local/libexec/samba/samba-backtrace] /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied /usr/local/libexec/samba/samba-backtrace: /usr/local/bin/gdb7111: not found /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied /usr/local/libexec/samba/samba-backtrace: /usr/local/bin/gdb7111: not found /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied /usr/local/libexec/samba/samba-backtrace: /usr/local/bin/gdb7111: not found /usr/local/libexec/samba/samba-backtrace: cannot create /var/log/samba4/samba.backtraces: Permission denied [2018/02/12 00:41:44.076218, 0, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/lib/util.c:824(smb_panic_s3) smb_panic(): action returned status 2 [2018/02/12 00:41:44.076348, 4, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/smbd/sec_ctx.c:216(push_sec_ctx) push_sec_ctx(1003, 65534) : sec_ctx_stack_ndx = 1 [2018/02/12 00:41:44.076454, 4, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/smbd/uid.c:491(push_conn_ctx) push_conn_ctx(3758314062) : conn_ctx_stack_ndx = 0 [2018/02/12 00:41:44.076524, 4, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/smbd/sec_ctx.c:320(set_sec_ctx_internal) setting sec ctx (0, 0) - sec_ctx_stack_ndx = 1 [2018/02/12 00:41:44.076617, 5, pid=45136, effective(1003, 65534), real(0, 0)] ../libcli/security/security_token.c:53(security_token_debug) Security token: (NULL) [2018/02/12 00:41:44.076716, 5, pid=45136, effective(1003, 65534), real(0, 0)] ../source3/auth/token_util.c:651(debug_unix_user_token) UNIX token of user 0 Primary group is 0 and contains 0 supplementary groups [2018/02/12 00:41:44.076919, 0, pid=45136, effective(0, 0), real(0, 0)] ../source3/lib/dumpcore.c:315(dump_core) dumping core in /var/db/system/cores [2018/02/12 00:41:44.806594, 10, pid=44741, effective(0, 0), real(0, 0)] ../source3/lib/messages_dgm.c:1344(messaging_dgm_send) messaging_dgm_send: Sending message to 44769 [2018/02/12 00:41:44.807077, 3, pid=44741, effective(0, 0), real(0, 0)] ../source3/smbd/server.c:868(remove_child_pid) ../source3/smbd/server.c:867 Unclean shutdown of pid 45136 [2018/02/12 00:41:44.807130, 10, pid=44769, effective(0, 0), real(0, 0)] ../source3/lib/messages.c:203(messaging_recv_cb) messaging_recv_cb: Received message 0x314 len 0 (num_fds:0) from 44741 [2018/02/12 00:41:44.807482, 10, pid=44769, effective(0, 0), real(0, 0)] ../source3/lib/messages_dgm.c:1469(messaging_dgm_cleanup) messaging_dgm_cleanup: Cleaning up : No error: 0 [2018/02/12 00:41:44.807810, 5, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap.c:160(dbwrap_check_lock_order) check lock order 2 for /var/lock/serverid.tdb [2018/02/12 00:41:44.807932, 10, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap.c:115(debug_lock_order) lock order: 1:<none> 2:/var/lock/serverid.tdb 3:<none> [2018/02/12 00:41:44.808078, 10, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap_tdb.c:59(db_tdb_log_key) Locking key 50B0000000000000FFFF [2018/02/12 00:41:44.808260, 10, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap_tdb.c:143(db_tdb_fetch_locked_internal) Allocated locked data 0x0x81284d960 [2018/02/12 00:41:44.808428, 10, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap_tdb.c:59(db_tdb_log_key) Unlocking key 50B0000000000000FFFF [2018/02/12 00:41:44.808500, 5, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap.c:128(dbwrap_lock_order_state_destructor) release lock order 2 for /var/lock/serverid.tdb [2018/02/12 00:41:44.808568, 10, pid=44769, effective(0, 0), real(0, 0)] ../lib/dbwrap/dbwrap.c:115(debug_lock_order) lock order: 1:<none> 2:<none> 3:<none> [2018/02/12 00:41:44.808635, 10, pid=44769, effective(0, 0), real(0, 0)] ../source3/smbd/smbd_cleanupd.c:210(smbd_cleanupd_process_exited) smbd_cleanupd_process_exited: cleaned up pid 45136 [2018/02/12 00:41:44.811634, 10, pid=45147, effective(0, 0), real(0, 0)] ../source3/lib/messages_dgm_ref.c:157(msg_dgm_ref_destructor) msg_dgm_ref_destructor: refs=0x0 [2018/02/12 00:41:44.812399, 10, pid=45147, effective(0, 0), real(0, 0)] ../source3/lib/messages_dgm_ref.c:79(messaging_dgm_ref) messaging_dgm_ref: messaging_dgm_init returned No error: 0 [2018/02/12 00:41:44.812510, 10, pid=45147, effective(0, 0), real(0, 0)] ../source3/lib/messages_dgm_ref.c:108(messaging_dgm_ref) messaging_dgm_ref: unique = 13072513250355267000 [2018/02/12 00:41:44.814980, 10, pid=45147, effective(0, 0), real(0, 0)] ../source3/smbd/smbXsrv_client.c:534(smbXsrv_client_create) [2018/02/12 00:41:44.815064, 10, pid=45147, effective(0, 0), real(0, 0)] ../source3/smbd/smbXsrv_client.c:542(smbXsrv_client_create) smbXsrv_client_create: client_guid[00000000-0000-0000-0000-000000000000] stored
Dmesg
pid 1756 (syslog-ng), uid 0: exited on signal 6 (core dumped) pid 12705 (smbd), uid 0: exited on signal 6 (core dumped) pid 12716 (smbd), uid 0: exited on signal 6 (core dumped) pid 12727 (smbd), uid 0: exited on signal 6 (core dumped) pid 12908 (smbd), uid 0: exited on signal 6 (core dumped) pid 12929 (smbd), uid 0: exited on signal 6 (core dumped) pid 13016 (smbd), uid 0: exited on signal 6 (core dumped) pid 13119 (smbd), uid 0: exited on signal 6 (core dumped) pid 13175 (smbd), uid 0: exited on signal 6 (core dumped) pid 13851 (smbd), uid 0: exited on signal 6 (core dumped) pid 14269 (smbd), uid 0: exited on signal 6 (core dumped) pid 14383 (smbd), uid 0: exited on signal 6 (core dumped) pid 14394 (smbd), uid 0: exited on signal 6 (core dumped) pid 44890 (smbd), uid 0: exited on signal 6 (core dumped) pid 44902 (smbd), uid 0: exited on signal 6 (core dumped) pid 44913 (smbd), uid 0: exited on signal 6 (core dumped) pid 44924 (smbd), uid 0: exited on signal 6 (core dumped) pid 44935 (smbd), uid 0: exited on signal 6 (core dumped) pid 45029 (smbd), uid 0: exited on signal 6 (core dumped) pid 45125 (smbd), uid 0: exited on signal 6 (core dumped) pid 45136 (smbd), uid 0: exited on signal 6 (core dumped) pid 46829 (smbd), uid 0: exited on signal 6 (core dumped) pid 47134 (smbd), uid 0: exited on signal 6 (core dumped) pid 47399 (smbd), uid 0: exited on signal 6 (core dumped) pid 47410 (smbd), uid 0: exited on signal 6 (core dumped)
socket options = TCP_NODELAY SO_RCVBUF=1048576 SO_SNDBUF=1048576 IPTOS_LOWDELAY IPTOS_THROUGHPUT use sendfile = no min receivefile size = 131072 aio read size = 1 aio write size = 1 aio write behind = true read raw = yes local master = yes os level = 255 preferred master = yes posix locking = no server max protocol = SMB2_10
32 gig ECC RAM
