Hi, sorry for the late answer. The problem is still there...
The error message is:
Mar 15 16:09:03 haziserv smbd[20935]: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsreceive_smb_raw_talloc failed for client ipv4:192.168.1.121:51298 read error = NT_STATUS_CONNECTION_RESET.
My smb4.conf is:
[global]
server max protocol = SMB2
interfaces = 127.0.0.1 192.168.1.200
bind interfaces only = yes
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 466418
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
directory name cache size = 0
kernel change notify = no
dfree command = /usr/local/libexec/samba/dfree
ea support = yes
store dos attributes = yes
time server = yes
acl allow execute always = true
acl check permissions = true
dos filemode = yes
domain logons = no
local master = yes
idmap config *: backend = tdb
server role = standalone
netbios name = HAZISERV
workgroup = WORKGROUP
security = user
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
[Document]
path = /mnt/pool1/docs
comment = Documents
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
recycle:repository = .recycle/%U
recycle:keeptree = yes
recycle:versions = yes
recycle:touch = yes
recycle:directory_mode = 0777
recycle:subdir_mode = 0700
shadow:snapdir = .zfs/snapshot
shadow:sort = desc
shadow:localtime = yes
shadow:format = auto-%Y%m%d.%H%M-1w
shadow:snapdirseverywhere = yes
vfs objects = shadow_copy2 zfsacl
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
