SMB Share added with ALL usernames
markst
I am trying to setup home shares. TrueNAS creates the correct directories BUT in windows, it adds every user with the same directory files. If I switch logged in user the files change to that user's files BUT also all the other user's directories too.
Thanks for the help in advance.
Windows Explorer showing all users. Here mstoehr is logged in. (currently only 2 users created in TrueNAS)
mstoehr's File folder content with a file called mark.txt
jdoe's file folder showing all the files from the mstoehr folder
The Directories are shown with WinSCP
TrueNAS Users Setup. All users setup this way
TrueNAS SMB Share
anodos
Sambassador
There was a bug in upstream samba in handling homes shares with registry shares. I have fixed it in upstream master and 12.0-stable (will be U1).
In this case though the path suffix has %U which locks you into the path of the currently authenticated user. You can verify your connect path via "smbstatus".
markst
Thanks for the super-fast response. I am a newbie and need a bit of more help getting it to work. Here is smbstatus when mstoehr is logged in
anodos
Sambassador
The way that we generate the share path prevents users from accessing other user's home directories. If you manually try to access someone else's share you will be dumped in your own. In this case, your client should only have seen the mstoehr share. Not sure off the top of my head why you're seeing both users ones. Perhaps we're generating the results of "net share enum" incorrectly :/
