SOLVED SMB Copy only 500 Mbit Truenas 12.beta.2.1
amichelf
I realized that when copying data to and from my box I usually get only about 500-600Mbit over an Gigabit link, so the network is not fully saturated. It is not the network, because when I copy the same data from the same client to a windows server, I get the NIC saturated. I am not copying a lot of smaller files, even a 15 GB vhd is copied only at 500 Mbit.
I can rule out the hardware as on freenas it was not an issue to get full Gbit transfer.
Might this be caused on the implementations of the SMB Server and is therer any parameter for me to tune the performance here?
anodos
Sambassador
What is output of testparm -s? Generally speaking, "tuning" should be avoided for the SMB service as most online guides are either dated or chock-full of bad advice.
amichelf
Hi anodos,
thank you for the reply, I did not modify not want to change any setting
root@storage[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_DOMAIN_MEMBER
# Global parameters
[global]
        aio max threads = 2
        allow trusted domains = No
        bind interfaces only = Yes
        client ldap sasl wrapping = seal
        disable spoolss = Yes
        dns proxy = No
        domain master = No
        enable web service discovery = Yes
        kerberos method = secrets and keytab
        kernel change notify = No
        load printers = No
        local master = No
        logging = file
        max log size = 51200
        preferred master = No
        realm = DOMAIN.COM
        registry shares = Yes
        restrict anonymous = 2
        security = ADS
        server role = member server
        template shell = /bin/sh
        unix extensions = No
        winbind cache time = 7200
        winbind enum groups = Yes
        winbind enum users = Yes
        winbind max domain connections = 10
        workgroup = DOMAIN
        idmap config amich
amichelf
I am sorry and thank you for your patience:
# Global parameters
[global]
        aio max threads = 2
        dns proxy = No
        domain master = No
        load printers = No
        local master = No
        logging = file
        realm = DOMAIN.COM
        security = ADS
        workgroup = DOMAIN
        idmap config domain: range = 20000-90000000
        idmap config domain: backend = rid
        idmap config * : backend = tdb
        directory name cache size = 0
        dos filemode = Yes
[Kopfinger]
        ea support = No
        kernel share modes = No
        path = /mnt/Pool/Kopfinger
        posix locking = No
        read only = No
        vfs objects = aio_fbsd shadow_copy_zfs ixnas
        nfs4:chown = true
[Backup]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Backup
        posix locking = No
        read only = No
        nfs4:chown = true
[Bilder]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Bilder
        posix locking = No
        read only = No
        nfs4:chown = true
[Media]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Media
        posix locking = No
        read only = No
        nfs4:chown = true
[Music]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Music
        posix locking = No
        read only = No
        nfs4:chown = true
[Private]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Private
        posix locking = No
        read only = No
        nfs4:chown = true
[Storage]
        ea support = No
        path = /mnt/Pool/SMB-Shares/Storage
        posix locking = No
        read only = No
        nfs4:chown = true
[VeeamBackup]
        ea support = No
        path = /mnt/Pool/SMB-Shares/VeeamBackup
        posix locking = No
        read only = No
        nfs4:chown = true
[VeeamHW]
        ea support = No
        path = /mnt/Pool/SMB-Shares/VeemHW
        posix locking = No
        read only = No
        nfs4:chown = true
