MikhailCompo
- Jan 4, 2018
SMB v3 and the Multichannel feature was introduced to Server 2012 and allows for increased bandwidth simply by plugging more network cables into the switch from the same machine.
e.g. I added one quad NIC card each to my two servers, connected the cables to my switch and the bandwidth between the two servers jumped from 110MB/s ish (maxed out) to about 370MB/s. There is no HW support required on the switch - no teaming required; and no special configuration in Windows, it works out of the box.
The cost for the increase in bandwidth above was >£50.
The next step up to increase bandwidth between those two servers would be 10GBE which would be a minimum of £100 per NIC and £500 for the switch.
Although the cost of 10GBE is coming down all the time, it is still prohibitive for a significant number of users of FreeNAS.
Therefore, will/when will FreeNAS support SMB 3 and Multichannel to achieve this significant price/performance boon?
