Last I heard SMB multichannel on Samba was experimental and not ready for production, ie, there's a chance of data corruption.
I haven't. Feel free to try it and report back.Yes, but has anyone tried it on FreeNAS? That's the question.
Any update on this? Will it come in 11.1 maybe? - as normal feature - non-experimental.
server multi channel support = yes aio read size = 1 aio write size = 1
not that I can tell (did a quick md5 hash)... why? Did you experience issues with corrupted data?Is all your data fine? No mystery corruption?
This extension should be used with care and are mainly intended
for testing. See the smb.conf manual page for details.
CAVEAT: While this should be working without problems mostly,
there are still corner cases in the treatment of channel failures
that may result in DATA CORRUPTION when these race conditions hit.
It is hence
NOT RECOMMENDED TO USE MULTI-CHANNEL IN PRODUCTION
at this stage. This situation can be expected to improve during
the life-time of the 4.4 release. Feed-back from test-setups is
highly welcome.[/quote
