smartd not running?
OCMaximus
So... I deleted my last volume. Swapped out the 3x2tb Green HDDs in RAIDZ1 for 6x3TB Red HHDs in RAIDZ2 and now SMARTD is not running. Before it would run every 30 min and show status in the Show console messages in the footer and now all I get is whats below.
Apr 19 17:50:25 freenas notifier: Stopping smartd.
Apr 19 17:50:25 freenas notifier: smartd not running? (check /var/run/smartd.pid).
Apr 19 17:50:25 freenas notifier: Starting smartd.
All 6 drives have S.M.A.R.T. enabled.
S.M.A.R.T. is "ON" under services.
System has been shut down completely and restarted.
S.M.A.R.T. Settings:
Check interval 30
Power mode Never - Check the device regardless of its power mode
Difference 0
Informal 0
Critical 0
Email to report My Email
No additional CRON jobs or S.M.A.R.T. Test.
Any idea on how to get smartd started again?
Thanks,
OCM
joeschmuck
Old Man
First, what is RAIDZ6 ?
Second, I know it's obvious but did you power off (meaning power off not reboot) your system and turn it back on again? This typically gets it working again.
Also I truly hate the "Power mode Never" and then it says it will check the drives, not your fault, I just think it's stupid wording.
Also, help us help you, give us some specifics of your system and software. Are you running 8.3.1-Release-p1 ? -p2 dirty? what? What drives, MB, etc...
OCMaximus
RAIDZ2, typo, I was thinking Raid-6.
System has been powered off completely and restarted various times.
Is "Power mode Never" an incorrect setting?
Build: FreeNAS-8.3.0-RELEASE-p1-x64 (r12825)
Platform: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
Memory: 16057MB
HDD: 6x3TB WD Reds
joeschmuck
Old Man
Yes, "Never" is a valid and good setting for SMART to operate.
I need to take a step back here because I read your original posting again, so what is you problem again? Based on the messages
The last message states smartd is starting. No error message after that. Is the SMART service listed as "ON" ?
You can check is smartd is running by typing at a console window 'ps -A | more' and look through the data for 'usr/local/sbin/smartd' with some additional data on the end of the line.
So I triggered off the fact that you thought you had a problem when I should have paid more attention to what you said. I don't think you have a problem at all.
OCMaximus
OK, so this is what I found.
10057 ?? I 0:00.03 /usr/local/sbin/smartd -i 1800 -c /usr/local/etc/smart
Is smartd running?
If so, why is there no evidence of smartd checking the disks in the console footer as before?
smartd -q showtests
smartd 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p5 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Opened configuration file /usr/local/etc/smartd.conf
Drive: /dev/ada0, implied '-a' Directive on line 4 of file /usr/local/etc/smartd
.conf
Drive: /dev/ada1, implied '-a' Directive on line 5 of file /usr/local/etc/smartd
.conf
Drive: /dev/ada2, implied '-a' Directive on line 6 of file /usr/local/etc/smartd
.conf
Drive: /dev/ada3, implied '-a' Directive on line 7 of file /usr/local/etc/smartd
.conf
Drive: /dev/ada4, implied '-a' Directive on line 8 of file /usr/local/etc/smartd
.conf
Drive: /dev/ada5, implied '-a' Directive on line 9 of file /usr/local/etc/smartd
.conf
Configuration file /usr/local/etc/smartd.conf parsed.
Device: /dev/ada0, opened
Device: /dev/ada0, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T3309461, WWN:5-0014ee-65889
e050, FW:80.00A80, 3.00 TB
Device: /dev/ada0, not found in smartd database.
Device: /dev/ada0, is SMART capable. Adding to "monitor" list.
Device: /dev/ada1, opened
Device: /dev/ada1, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T2364889, WWN:5-0014ee-6587b
8ba2, FW:80.00A80, 3.00 TB
Device: /dev/ada1, not found in smartd database.
Device: /dev/ada1, is SMART capable. Adding to "monitor" list.
Device: /dev/ada2, opened
Device: /dev/ada2, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T2253947, WWN:5-0014ee-00385
1880, FW:80.00A80, 3.00 TB
Device: /dev/ada2, not found in smartd database.
Device: /dev/ada2, is SMART capable. Adding to "monitor" list.
Device: /dev/ada3, opened
Device: /dev/ada3, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T1685668, WWN:5-0014ee-0ae29
d5a4, FW:80.00A80, 3.00 TB
Device: /dev/ada3, not found in smartd database.
Device: /dev/ada3, is SMART capable. Adding to "monitor" list.
Device: /dev/ada4, opened
Device: /dev/ada4, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T0824223, WWN:5-0014ee-65839
e145, FW:80.00A80, 3.00 TB
Device: /dev/ada4, not found in smartd database.
Device: /dev/ada4, is SMART capable. Adding to "monitor" list.
Device: /dev/ada5, opened
Device: /dev/ada5, WDC WD30EFRX-68AX9N0, S/N:WD-WMC1T1729473, WWN:5-0014ee-058d4
1fab, FW:80.00A80, 3.00 TB
Device: /dev/ada5, not found in smartd database.
Device: /dev/ada5, is SMART capable. Adding to "monitor" list.
Monitoring 6 ATA and 0 SCSI devices
Next scheduled self tests (at most 5 of each type per device):
Totals [Sun Apr 21 08:12:58 2013 HST - Sat Jul 20 08:12:58 2013 HST]:
Device: /dev/ada0, will do   0 tests of type L
Device: /dev/ada0, will do   0 tests of type S
Device: /dev/ada0, will do   0 tests of type C
Device: /dev/ada0, will do   0 tests of type O
Device: /dev/ada1, will do   0 tests of type L
Device: /dev/ada1, will do   0 tests of type S
Device: /dev/ada1, will do   0 tests of type C
Device: /dev/ada1, will do   0 tests of type O
Device: /dev/ada2, will do   0 tests of type L
Device: /dev/ada2, will do   0 tests of type S
Device: /dev/ada2, will do   0 tests of type C
Device: /dev/ada2, will do   0 tests of type O
Device: /dev/ada3, will do   0 tests of type L
Device: /dev/ada3, will do   0 tests of type S
Device: /dev/ada3, will do   0 tests of type C
Device: /dev/ada3, will do   0 tests of type O
Device: /dev/ada4, will do   0 tests of type L
Device: /dev/ada4, will do   0 tests of type S
Device: /dev/ada4, will do   0 tests of type C
Device: /dev/ada4, will do   0 tests of type O
Device: /dev/ada5, will do   0 tests of type L
Device: /dev/ada5, will do   0 tests of type S
Device: /dev/ada5, will do   0 tests of type C
Device: /dev/ada5, will do   0 tests of type O
(END)
smartctl -a /dev/ada0
Device Model:     WDC WD30EFRX-68AX9N0
Serial Number:    WD-WMC1T3309461
LU WWN Device Id: 5 0014ee 65889e050
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ACS-2 (revision not indicated)
Local Time is:    Sun Apr 21 08:17:25 2013 HST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (40380) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp
ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 405) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_
FAILED RAW_VALUE
1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -
       0
  3 Spin_Up_Time            0x0027   182   182   021    Pre-fail  Always       -
       5858
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -
       8
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -
       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -
       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -
       589
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -
       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -
       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -
       8
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -
       5
194 Temperature_Celsius     0x0022   112   108   000    Old_age   Always       -
       38
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -
       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -
       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -
       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -
       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -
       0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA
_of_first_error
# 1  Short offline       Completed without error       00%       550         -
# 2  Short offline       Completed without error       00%       549         -
# 3  Short offline       Completed without error       00%       548         -
# 4  Short offline       Completed without error       00%       547         -
# 5  Short offline       Completed without error       00%       546         -
# 6  Short offline       Completed without error       00%       545         -
# 7  Short offline       Completed without error       00%       544         -
# 8  Short offline       Completed without error       00%       543         -
# 9  Short offline       Completed without error       00%       542         -
#10  Short offline       Completed without error       00%       541         -
#11  Short offline       Completed without error       00%       541         -
#12  Short offline       Completed without error       00%       539         -
#13  Short offline       Completed without error       00%       538         -
#14  Short offline       Completed without error       00%       537         -
#15  Short offline       Completed without error       00%       536         -
#16  Short offline       Completed without error       00%       536         -
#17  Short offline       Completed without error       00%       535         -
#18  Short offline       Completed without error       00%       535         -
#19  Short offline       Completed without error       00%       535         -
#20  Short offline       Completed without error       00%       508         -
#21  Short offline       Completed without error       00%       507         -
[root@freenas ~]#
I hope this is enough information to determine what the frak is going on.
OCMaximus
smartctl -i /dev/ada0
[root@freenas ~]# smartctl -i /dev/ada0
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p5 amd64] (local build)
ATA Version is:   8
Local Time is:    Sun Apr 21 08:31:03 2013 HST
[root@freenas ~]#
Could this be the problem? I'm using WD Reds with Build: FreeNAS-8.3.0-RELEASE-p1-x64 (r12825)
joeschmuck
Old Man
Smartd is running on your machine. Just because a drive isn't in the smartctl database doesn't mean things are not working and smartctl hasn't changed in quite sometime. I chatted with Bruce last year about a problem and he updated the code, since then I don't expect to see another update anytime soon.
Holy cow, you had a short test scheduled for every hour? Damn, that's excessive! But hey, it's up to you. So what you are saying is that in the past 39 hours of system run time that there hasn't been a short SMART test? Did you setup the system to perform a SMART test and the periodicity? Sounds like operator error to me right now assuming I understand what you want done.
Post a screen capture of the GUI --> Left column --> System --> S.M.A.R.T Tests --> View S.M.A.R.T. Tests
Stephens will get angry with you now. :P
joeschmuck
Old Man
I will not entertain that kind of craziness. That was just nuts wasn't it? If I had time to debate that well I would but in another thread.
Cheers!
P.S. remember when you had only a few postings, look at you now!
OCMaximus
Only ran it every hour as a test to see if it was actually running. I have since then deleted that SMART test since it never actually ran at all. At least that what I think.
I've started a new daily test. 2200 everyday to see what happens. First test should start in an hour. How can I make sure smart is actually running as tasked?
Cheers!
I wasn't poking fun at anyone. Everyone has to start somewhere. I was just trying to get a laugh. If we can't laugh at ourselves who can we laugh at?
joeschmuck
Old Man
Oh I did laugh, it was funny.
- - - Updated - - -
@OCMax
To see if the test worked, type in 'smartctl -a /dev/ada0' and compare the #9 Power on hours value to the SMART Test results. That will tell you when the smart test was completed.
The only time you should get an email is when it fails the test. You could create a script which will forward the results if you like, search for it on these forums as there are a few of them but one thread which I started has the largest participation and there are a few very good scripts there.
EDIT: Here is the thread if you want to pursue this: http://forums.freenas.org/showthread.php?6211-Setup-SMART-Reporting-via-email
OCMaximus
@OCMax
Huhh, compare the #9 Power on hours value to what SMART Test results? :confused:
ATA Version is:   8
Local Time is:    Mon Apr 22 00:28:11 2013 HST
                                        been run.
ort.
                                        command.
                                        power-saving mode.
FAILED RAW_VALUE
       0
       5858
       8
       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -
       0
       605
       0
       0
       8
       5
       38
       0
       0
       0
       0
       0
No Errors Logged
_of_first_error
# 1  Short offline       Completed without error       00%       603         -
# 2  Short offline       Completed without error       00%       550         -
# 3  Short offline       Completed without error       00%       549         -
# 4  Short offline       Completed without error       00%       548         -
# 5  Short offline       Completed without error       00%       547         -
# 6  Short offline       Completed without error       00%       546         -
# 7  Short offline       Completed without error       00%       545         -
# 8  Short offline       Completed without error       00%       544         -
# 9  Short offline       Completed without error       00%       543         -
#10  Short offline       Completed without error       00%       542         -
#12  Short offline       Completed without error       00%       541         -
#13  Short offline       Completed without error       00%       539         -
#14  Short offline       Completed without error       00%       538         -
#15  Short offline       Completed without error       00%       537         -
#17  Short offline       Completed without error       00%       536         -
#20  Short offline       Completed without error       00%       535         -
#21  Short offline       Completed without error       00%       508         -
[root@freenas ~]#
Also, I've been trying to log into SSH without any luck. For some reason Putty will not take my root password to give me access to my NAS box.
Thats a whole other issue I'm currently working on. Copy/Paste in Shell
Operator Error??? :o
I do thank you all for your help. :D
dzo-o
hi all
I am new to Freenas, but i seem to be stuck on Feb 14 21:25:17 freenas root: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
how can i fix this?
  • Forum_nas.txt
MrToddsFriends
Documentation Browser
Please provide hardware details as per the forum rules. Are the HDDs connected using a Hardware RAID Controller?
dzo-o
I will try my best. I am new to all this talk, I have a dell Poweredge r715 with 6 SAS drives:
3x600GB
3x300GB
That gives me 6 Virtual Disks which I can see in FreeNas. I have created two volumes, both in Raidz.
I configured each of the 6 drives as a Raid0 Virtual Disk in my BIOS.
Linkman
My guess would be because you're running with "RAID0 virtual disks" and aren't passing the discs directly through to FreeNAS.
dzo-o
how do I fix this?
MrToddsFriends
how do I fix this?
The first step would be to find out which HW RAID controller is used. Some models (Dell H200 and H310 for example) can be reflashed to IT-Mode, in which they operate as host bus adapter (HBA) with no unwanted RAID functionality.
dzo-o
Thank you, I will look into this. I have a Dell Poweredge R715 - not sure where to begin. I will start doing my research now.
