tmacka88
- Jul 5, 2011
For some reason my SMB share has stopped working. I am not sure if an update stopped something from working.
I have 1 volume that store my media (which is not in a dataset). AFP share works fine with this, but on XBMC when I select SMB shares FreeNAS doe not show up at all.
I turned the CIFS off then on again and notice this in the log in the footer.
Any help would be great.
Thanks
Sep 25 17:19:21 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Sep 25 17:19:22 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: zfs list -H -o mountpoint,name
Sep 25 17:19:22 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmp8ODWbU -s /usr/local/etc/smb4.conf -e tdbsam:/var/etc/private/passdb.tdb
Sep 25 17:19:22 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/net groupmap list
Sep 25 17:19:22 FreeNAS notifier: Performing sanity check on Samba configuration: FAILED
Sep 25 17:19:29 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Sep 25 17:19:29 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: zfs list -H -o mountpoint,name
Sep 25 17:19:29 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmpV0cRoK -s /usr/local/etc/smb4.conf -e tdbsam:/var/etc/private/passdb.tdb
Sep 25 17:19:29 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/net groupmap list
Sep 25 17:19:29 FreeNAS notifier: winbindd not running? (check /var/run/samba/winbindd.pid).
Sep 25 17:19:29 FreeNAS notifier: smbd not running? (check /var/run/samba/smbd.pid).
Sep 25 17:19:29 FreeNAS notifier: nmbd not running? (check /var/run/samba/nmbd.pid).
Sep 25 17:19:34 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Sep 25 17:19:34 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: zfs list -H -o mountpoint,name
Sep 25 17:19:34 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmpggCtNf -s /usr/local/etc/smb4.conf -e tdbsam:/var/etc/private/passdb.tdb
Sep 25 17:19:34 FreeNAS generate_smb4_conf.py: [common.pipesubr:58] Popen()ing: /usr/local/bin/net groupmap list
Sep 25 17:19:34 FreeNAS notifier: winbindd not running? (check /var/run/samba/winbindd.pid).
Sep 25 17:19:34 FreeNAS notifier: smbd not running? (check /var/run/samba/smbd.pid).
Sep 25 17:19:34 FreeNAS notifier: nmbd not running? (check /var/run/samba/nmbd.pid).
Sep 25 17:19:34 FreeNAS notifier: Performing sanity check on Samba configuration: FAILED
Thanks
