So I got some new old drives I wanted to test out - 3TB HGST HUS724030ALS640 for $18 / piece and these have ~39k hours. One drive showed a smart test error "Failed in second segment" with 0 hours, though the drive ran "fine" for 39,000 hours before I got it.
After I got the drive, I did a burn in of the drive : short -> long -> badblocks -> long smart tests and I did not see any more errors. So I deployed the drive and with the first scheduled short smart test, I noticed the Smart test error "Failed in second segment" again.
My questions-
How can 3 smart tests not get the error and the 4th gets it again? It is not the drive that worries me (plenty of spares), but that the burn-in tests did not catch this.
Does anybody know what this error really means? Just curious, I could not find it.
I noticed @Johnny Fartpants points out that this error isnot a real issue. (correction)
www.ixsystems.com
Full Smart
SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Failed in second segment 2 39499 - [0x4 0x3e 0x3] # 2 Background long Completed - 39442 - [- - -] # 3 Background long Completed - 39378 - [- - -] # 4 Background short Completed - 39371 - [- - -] # 5 Background short Failed in second segment 2 0 - [0x4 0x3e 0x3]
My questions-
SAS Smart self test results confusing.... Help needed
Hi all, I am currently in the process of building a new NAS and was doing the hard drive burning in procedure per our forum guide. Encountered some strange results and since this is my first SAS build I am at a loss wat to do... System is a Non ECC motherboard with the latest Freenas release...
Full Smart
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: HGST Product: HUS724030ALS640 Revision: A124 Compliance: SPC-4 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Logical block size: 512 bytes LU is resource provisioned, LBPRZ=0 Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000cca027c3f6f4 Serial number: P8KGSZHW Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Wed May 20 09:49:15 2020 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 38 C Drive Trip Temperature: 85 C Manufactured in week 12 of year 2014 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 12 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 1660 Elements in grown defect list: 0 Vendor (Seagate Cache) information Blocks sent to initiator = 2080889374769152 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 2830 0 0 2830 119345 173407.046 0 write: 0 0 0 0 13163 13281.664 0 verify: 64340 0 0 64340 682 1236.761 0 Non-medium error count: 0 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Failed in second segment 2 39499 - [0x4 0x3e 0x3] # 2 Background long Completed - 39442 - [- - -] # 3 Background long Completed - 39378 - [- - -] # 4 Background short Completed - 39371 - [- - -] # 5 Background short Failed in second segment 2 0 - [0x4 0x3e 0x3] Long (extended) Self-test duration: 29637 seconds [493.9 minutes]
