SMART results: VALUE or RAW_VALUE? + All drives failing #2 Extended Offline Interrupted (host reset)
EvanVanVan
I woke up to a degrade yesterday (see the attached pic, please excurse the picture of the computer screen. I was more concerned with a easily searchable, forever photo rather than best screenshotting practices). After restarting TrueNAS, the drive disappeared completely, hoping it was a communication error I just swapped the cables and it came back online. I just completed a long smart test and I'm wondering if the #5, #197 and #198 non-zero VALUE is an issue or the 0 RAW_VALUE means they're ok?
root@freenas:~ # smartctl -a /dev/da6
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build)
Model Family:     Western Digital Ultrastar He10/12
Device Model:     WDC WD100EMAZ-00WJTA0
Serial Number:    XXXXXXXXX
LU WWN Device Id: 5 000cca 273dd9015
Firmware Version: 83.H0A83
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Oct 14 07:16:37 2022 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1239) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   128   128   054    Old_age   Offline      -       116
  3 Spin_Up_Time            0x0007   166   166   024    Pre-fail  Always       -       433 (Average 358)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       57
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       33916
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       57
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1421
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1421
194 Temperature_Celsius     0x0002   216   216   000    Old_age   Always       -       30 (Min/Max 19/40)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     33912         -
# 2  Extended offline    Interrupted (host reset)      10%     33783         -
# 3  Short offline       Completed without error       00%     33697         -
# 4  Short offline       Completed without error       00%     33481         -
# 5  Extended offline    Completed without error       00%     33406         -
# 6  Short offline       Completed without error       00%     33313         -
# 7  Short offline       Completed without error       00%     33145         -
# 8  Extended offline    Completed without error       00%     33070         -
# 9  Short offline       Completed without error       00%     32977         -
#10  Short offline       Completed without error       00%     32737         -
#11  Extended offline    Completed without error       00%     32662         -
#12  Short offline       Completed without error       00%     32569         -
#13  Short offline       Completed without error       00%     32401         -
#14  Extended offline    Completed without error       00%     32326         -
#15  Short offline       Completed without error       00%     32233         -
#16  Short offline       Completed without error       00%     31993         -
#17  Extended offline    Completed without error       00%     31918         -
#18  Short offline       Completed without error       00%     31825         -
#19  Short offline       Completed without error       00%     31657         -
#20  Extended offline    Completed without error       00%     31582         -
#21  Short offline       Completed without error       00%     31489         -
Also, as you can see in these results there one error/issue.
Every one of my drives seems to have the same error with #2 Extended offline test failing with 10% remaining. Is this an issue?
Thanks
emk2203
Disk looks fine to me, did you perhaps cancel the SMART test by a reboot or sth? Brownout in case you don't use UPS? Re-run the test.
