pr1malr8ge
- Dec 10, 2017
All,
I'm running around in circles with Smart issues on some new to me Sas HGST 10tb Helium drives. I've been discussing the issue over at Serve the home at this link
forums.servethehome.com
So here is all that has happened.
Currently my setup is a ESXi with truenas-core in a VM with a supermicro s3008l-l8e HBA passed through to truenas-core.
running smartclt -a on the 10tb sas drives outputs little when compared to my 3tb sata drives. all on the same expander and hba
I'm more talking about the Vendor Specific SMART Attributes with Thresholds: where off line uncorrectables and other things are shown. On the servethehome forums
one person whom has basically the same exact drive but in sata format gets helium levels outputs.
The very bottom of this post will show the sata version of this 10tb drive output from a different persons computer.
I guess I'm confused as to why I the sas drives wont output like the sata drives. is it something I'm doing or my machine or a inherent on sas drives?
I've also looked at sg_logs -a /dev/da2 but not much more is given, along with no helium level report.
Refrence the 3tb hgst sata output
10tb hgst sata helium from some-one else
[Update: Seller Complaints Accumulating] HGST Ultrastar He10 - 10TB @ $129.95
I only flashed mine because I had drives with different firmware versions and I wanted them to all be uniform. So I figured i'd just flash to the latest so I wouldn't have to think about it again.
root@aeronas:~ # smartctl -a /dev/da2
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Vendor: HGST
Product: HUH721010AL42C0
Revision: A3Z4
Compliance: SPC-4
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Logical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca26a9c4c54
Serial number: 2TJSYR3D
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Mon Apr 18 17:34:04 2022 CDT
SMART support is: Enabled
Temperature Warning: Enabled
SMART Health Status: OK
Grown defects during certification <not available>
Total blocks reassigned during format <not available>
Total new blocks reassigned <not available>
Power on minutes since format <not available>
Current Drive Temperature: 33 C
Drive Trip Temperature: 85 C
Accumulated power on time, hours:minutes 28471:11
Manufactured in week 12 of year 2018
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 16
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 1201
Elements in grown defect list: 0
Vendor (Seagate Cache) information
Blocks sent to initiator = 5560368210378752
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 3 0 3 3654189 42666.751 0
write: 0 0 0 0 605101 145638.498 0
verify: 0 0 0 0 47085 0.000 0
Non-medium error count: 0
Self-test execution status: 99% of test remaining
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background long Self test in progress ... - NOW - [- - -]
# 2 Background short Completed - 28470 - [- - -]
# 3 Background long Aborted (by user command) - 28417 - [- - -]
# 4 Background long Self test in progress ... - NOW - [- - -]
# 5 Background short Completed - 28250 - [- - -]
Long (extended) Self-test duration: 65535 seconds [1092.2 minutes]
root@aeronas:~ # sg_logs -a /dev/da2
HGST HUH721010AL42C0 A3Z4
Supported log pages [0x0]:
0x00 Supported log pages [sp]
0x02 Write error [we]
0x03 Read error [re]
0x05 Verify error [ve]
0x06 Non medium [nm]
0x08 Format status [fs]
0x0d Temperature [temp]
0x0e Start-stop cycle counter [sscc]
0x0f Application client [ac]
0x10 Self test results [str]
0x15 Background scan results [bsr]
0x18 Protocol specific port [psp]
0x19 General Statistics and Performance [gsp]
0x1a Power condition transitions [pct]
0x2f Informational exceptions [ie]
0x30 Performance counters (Hitachi) [pc_hi]
0x37 Cache (seagate) [c_se]
Write error counter page [0x2]
Errors corrected without substantial delay = 0
Errors corrected with possible delays = 0
Total rewrites or rereads = 0
Total errors corrected = 0
Total times correction algorithm processed = 605104
Total bytes processed = 145638498430976 [145 TB]
Total uncorrected errors = 0
Read error counter page [0x3]
Errors corrected with possible delays = 3
Total errors corrected = 3
Total times correction algorithm processed = 3654189
Total bytes processed = 42666751246336 [42 TB]
Verify error counter page [0x5]
Total times correction algorithm processed = 47085
Total bytes processed = 303104
Non-medium error page [0x6]
Non-medium error count = 0
Format status page [0x8]
Format data out: <not available>
Temperature page [0xd]
Current temperature = 33 C
Reference temperature = 85 C
Start-stop cycle counter page [0xe]
Date of manufacture, year: 2018, week: 12
Accounting date, year: 2018, week: 12
Specified cycle count over device lifetime = 50000
Accumulated start-stop cycles = 16
Specified load-unload count over device lifetime = 600000
Accumulated load-unload cycles = 1201
Application client page [0xf]
00 0f 00 40 00 00 00 03 fc 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
..... [truncated after 64 of 16388 bytes (use '-H' to see the rest)]
Self-test results page [0x10]
Parameter code = 1, accumulated power-on hours = 0
self-test code: background extended [2]
self-test result: self test in progress [15]
Parameter code = 2, accumulated power-on hours = 28470
self-test code: background short [1]
self-test result: completed without error [0]
Parameter code = 3, accumulated power-on hours = 28417
self-test result: aborted by SEND DIAGNOSTIC [1]
Parameter code = 4, accumulated power-on hours = 0
Parameter code = 5, accumulated power-on hours = 28250
Background scan results page [0x15]
Status parameters:
Accumulated power on minutes: 1708281 [h:m 28471:21]
Status: background scan enabled, none active (waiting for BMS interval timer to expire)
Number of background scans performed: 169
Background medium scan progress: 0.00 %
Number of background medium scans performed: 169
Protocol Specific port page for SAS SSP (sas-2) [0x18]
relative target port id = 1
generation code = 2
number of phys = 1
phy identifier = 0
attached SAS device type: expander device
attached reason: SMP phy control function
reason: unknown
negotiated logical link rate: 12 Gbps
attached initiator port: ssp=0 stp=0 smp=0
attached target port: ssp=0 stp=0 smp=1
SAS address = 0x5000cca26a9c4c55
attached SAS address = 0x500304801eec03bf
attached phy identifier = 0
Invalid DWORD count = 0
Running disparity error count = 0
Loss of DWORD synchronization count = 0
Phy reset problem count = 0
Phy event descriptors:
Invalid word count: 0
Running disparity error count: 0
Loss of dword synchronization count: 0
Phy reset problem count: 0
relative target port id = 2
generation code = 2
number of phys = 1
phy identifier = 1
attached SAS device type: no device attached
attached reason: unknown
reason: power on
negotiated logical link rate: phy enabled; unknown rate
attached target port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca26a9c4c56
attached SAS address = 0x0
General Statistics and Performance [0x19]
Statistics and performance log parameter
number of read commands = 542418953
number of write commands = 331423772
number of logical blocks received = 35556274031
number of logical blocks transmitted = 10416687316
read command processing intervals = 0
write command processing intervals = 0
weighted number of read commands plus write commands = 0
weighted read command processing plus write command processing = 0
Idle time log parameter
idle time intervals = 1909181729
Time interval log parameter for general stats
time interval negative exponent = 2
time interval integer = 5
Power condition transitions page [0x1a]
Accumulated transitions to active = 36343
Accumulated transitions to idle_a = 36344
Accumulated transitions to idle_b = 0
Accumulated transitions to idle_c = 0
Accumulated transitions to standby_z = 0
Accumulated transitions to standby_y = 0
Informational Exceptions page [0x2f]
IE asc = 0x0, ascq = 0x0
Threshold temperature = 85 C [common extension]
parameter code = 0x1, contents in hex:
00 00 01 03 03 64 64 19
HGST/WDC performance counters page [0x30]
Zero Seeks = 13408
Seeks >= 2/3 = 23104
Seeks >= 1/3 and < 2/3 = 29458
Seeks >= 1/6 and < 1/3 = 46298
Seeks >= 1/12 and < 1/6 = 47242
Seeks > 0 and < 1/12 = 25610
Overrun Counter = 1
Underrun Counter = 45338
Device Cache Full Read Hits = 9220
Device Cache Partial Read Hits = 285890
Device Cache Write Hits = 406573
Device Cache Fast Writes = 468544
Device Cache Read Misses = 3146415
HGST/WDC miscellaneous page [0x37, 0x0]
Power on hours = 28471
Total Bytes Read = 42666751246336
Total Bytes Written = 145638498430976
Max Drive Temp (Celsius) = 35
GList Size = 0
Number of Information Exceptions = 0
MED EXC = 0
HDW EXC = 0
Total Read Commands = 542418953
Total Write Commands = 331423772
Flash Correction Count = 0
root@aeronas:~ # smartctl -a /dev/da9
Model Family: Hitachi/HGST Ultrastar 7K4000
Device Model: Hitachi HUS724030ALE641
Serial Number: P8G8KPWR
LU WWN Device Id: 5 000cca 22cc3e56f
Firmware Version: MJ8OA5F0
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Apr 18 17:36:01 2022 CDT
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 80
3 Spin_Up_Time 0x0007 119 119 024 Pre-fail Always - 521 (Average 522)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 23
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 121 121 020 Pre-fail Offline - 34
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 10744
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 314
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 314
194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 15/38)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 10584 -
# 2 Extended offline Completed without error 00% 10498 -
# 3 Short offline Completed without error 00% 10418 -
# 4 Short offline Completed without error 00% 10178 -
# 5 Extended offline Completed without error 00% 10091 -
# 6 Short offline Completed without error 00% 10023 -
# 7 Short offline Completed without error 00% 10013 -
# 8 Short offline Completed without error 00% 9846 -
# 9 Extended offline Completed without error 00% 9758 -
#10 Short offline Completed without error 00% 9678 -
#11 Short offline Completed without error 00% 9510 -
#12 Extended offline Completed without error 00% 9422 -
#13 Short offline Completed without error 00% 9342 -
#14 Short offline Completed without error 00% 9176 -
#15 Extended offline Completed without error 00% 9088 -
#16 Short offline Completed without error 00% 9043 -
#17 Short offline Completed without error 00% 9010 -
#18 Short offline Completed without error 00% 8770 -
#19 Extended offline Completed without error 00% 8682 -
#20 Short offline Completed without error 00% 8602 -
#21 Short offline Completed without error 00% 8434 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 103 3 Spin_Up_Time 0x0007 154 154 024 Pre-fail Always - 446 (Average 408) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 15 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 12798 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 088 088 000 Old_age Always - 14493 193 Load_Cycle_Count 0x0012 088 088 000 Old_age Always - 14493 194 Temperature_Celsius 0x0002 136 136 000 Old_age Always - 44 (Min/Max 19/53) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
