It is not trivial to figure out how to best configure SMART and how the SMART settings and the SMART tests work together.
I work with FreeNAS 8.2 and have following questions/issues:
Problem 1) if one installs SSD instead of harddrive and enables SMART on that SSD then smartd will not start if the SSD has no temperature reporting. Is there SMART extra option one could provide on "View Disks / Edit Disk" panel that would allow enabling SMART for that drive?
Question 2) If one disables SMART in "View Disks / Edit Disk" will self tests scheduled in "Systems / SMART tests" still run on that disk?
Question 3) Does the setting in "Services / SMART Settings / Power Mode" also apply to "Systems / SMART tests"? Or in other words if a drive is in standby mode will the short or long SMART test be skipped if Power Mode settings is "Standby"?
Question 4) a) When I create a self test e.g. at Each selected hour = 23 / Every N day of month = 14 and Day of Week = Friday that will execute the test at Friday 11pm every other week, correct?
Question 4) b) In same example, if I now change Day of the Week = Mo,Tu,We,Th,Fr,Sa,Su will the self test execute every day in one week and then no day the other week? (Or will it randomly choose a day and then wait 14 days?)
Question 4) c) If I select Each selected day of month = 3,13,23 and Day of week = Fr will the test only execute if Friday coincides with 3rd, 13th or 23rd of that month?
Urs
Urs
