SMART Failure: WARNING: ascq=0x95
fahadshery
I am getting this warning:
Device: /dev/sdh, SMART Failure: WARNING: ascq=0x95
Device info:
[HGST     HUC101818CS4205  NE02], lu id: 0x5000cca02c362848, S/N: 08GYTA1A, 1.80 TB
what does it mean??? been googling this ascq=0x95 but no luck :/
It's probably best to just run smartctl -a /dev/sdh and look at the output for details about what's happening.
Samuel Tai
Here are a couple of resources that might help:
1. The manual for your HGST model
2. https://www.t10.org/lists/asc-num.htm
0x95 is probably a vendor-specific code, which may indicate a problem with the drive's controller board.
  • 7899165.pdf
