SMART Errors after updating to 12.0-U2?
seanmcg182
Hey, so I just updated to 12.0-U2 earlier today... and since then, 2 semi-new disks (less than 500 hours each), out of my 3 total disks, have reported a failed SMART.
Attached SMART report for all 3 disks.
They are all Toshiba X300 8TB disks.
The two disks that are reporting an error were bought about a month apart (but both powered on first time at the same time)
Serial Numbers are nowhere near each other, so different batches I'm assuming.
Any advice on this?
Other specs:
Motherboard: Asrock B450M Pro 4
CPU: Ryzen 2700X
LSI SAS card
32GB 3200Mhz RAM
It's a common error with those disks, sometimes it goes away after a power cycle, possibly a firmware issue.
seanmcg182
wow, that's... mildly annoying.
I got 2 new ones when I built the server, because I've had good results with that third drive i posted a screenshot of../
9140 hours and not a single error.
but both of the new ones have this issue.
unfortunate.
Thank you for response.
Alecmascot
Your drives are running very hot, 50C.
Under 40C would prolong their lives.
seanmcg182
Yeahhhh I noticed that a yesterday and overnighted some fans. installed them this morning and temps are around 40C now :) appreciate the input!
