Slow speeds on AFP.
RKMStudios
Junior Member
This is my first post in this community, so I apologize if I don't give all the information that is needed. I am eager to learn, but very new to a lot of this.
I have a 2U all flash system purchased from iXsystems and I am having some difficulty maximizing the throughput to my clients. I've tried all types of shares, iSCSI came the closest to saturating the 10gbe connection on both read and write (~900w, ~1150r), but iSCSI doesn't quite work for our environment. We really need shared storage with simultaneous R/W access to each client. So NAS.
I have a lot of questions, but I am going to try and keep this first post narrowed to improving speeds on a AFP share. I am not using SMB or NFS, because the throughput was far worse. AFP gives me the best performance.
I've used four benchmarks and a control to arrive to the conclusion that I should expect more.
iXSystems Benchmarks:
iPerf: 9.41 Gbits/sec (client to server)
iPerf: 9.41 Gbits/sec (server to client)
Blackmagic Disk Speed Test: 706MBw 270MBr
AJA Disk Test: ~730MBw ~1000MBr
Internal DD:
[root@Phoenix /mnt/Avalon_Pool]# dd if=/dev/zero of=tmp.dat bs=2048k count=50k51200+0 records in
51200+0 records out
107374182400 bytes transferred in 42.921751 secs (2501626342 bytes/sec)
[root@Phoenix /mnt/Avalon_Pool]# dd if=tmp.dat of=/dev/null bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 44.755781 secs (2399113164 bytes/sec)
So as a control of sorts, I have a second home-built FreeNAS that i just made to learn the ropes. Here's the same benchmarks using the same client on the same network:
Homebrew FreeNAS
iPerf: 9.40 Gbits/sec (client to server)
iPerf: 9.40 Gbits/sec (server to client)
Blackmagic Disk Speed Test: 800MBw 1034MBr
AJA Disk Test: ~818MBw ~1049MBr
Internal DD:
[root@Resolve /mnt/Resolve_Database]# dd if=/dev/zero of=tmp.dat bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 17.173343 secs (6252375265 bytes/sec)
[root@Resolve /mnt/Resolve_Database]# dd if=tmp.dat of=/dev/null bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 10.285223 secs (10439655227 bytes/sec)
Now for the system specs:
iXSystems:
Intel Six Core Xeon 3104 (1.7Ghz)
32GB DDR4 2666Mhz
Pool: Striped 9x 1TB Samsung QVO
Intel X540-T2
Homebrew FreeNAS:
Intel Core i7 Quad-core (4.5Ghz)
32 GB Crucial 1600Mhz
GTX Titan X (Lol, it was actually all i had laying around)
Pool: 1 USB 120GB SSD drive. (Gets about 200-300MB/s on its own, not fast)
Chelsio Dual SFP+ Card
Client:
MacOS Mojave
Closing thoughts: By all accounts, it confuses me that the internal read write tests were so off base. Shouldn't the system with 9 striped SSDs be blazing fast? There's nine!
Questions for the community:
- How is the internal performance of the 9 striped raids only hitting about 2.4GB/s? Should it not be 9x 550MB/s?
- How can a much more meager (homebrew) system toast the iXSystem's performance?
- How can I improve tuning or settings on the iXSystems machine to improve the AFP performance?
(I'm already using Jumbo frames across the board)
Caveats:
- I know everyone is going to point out that BM Speed Test and AJA Benchmarks are circumstantial, which is why i put together a second test with the same client and different NAS, same tests.
- Beyond these tests, I can anecdotally say that all share types preform better on the Homebrew machine than the iXSystems build.
Thank you all for your time and thoughts, I really appreciate it!
RKMStudios
Junior Member
Alright, so I was able to get both FreeNAS servers to match in AFP performance. On the iXSystems, I had reset the interfaces and forgot to set it to jumbo frames, so that was the culprit.
On both systems I am getting 750-800MB write and 1050MB read over AFP.
I would like to refine my main question to:
How can I improve write speeds on AFP?
D
dlavigne
Guest
Did you come up with any solutions that improved write speed?
RKMStudios
Junior Member
Not yet, occasionally I am seeing ~900MB write, and read is close to 1100MB. Both systems. It seems like I should be able to saturate ~1100 write fine, but no dice so far. The closest I can get is with iSCSI. It doesn't kill my workflow, as read speed is more important for us, but it does feel like something we should be able to overcome. The whole point of an all flash RAID is to saturate IO.
