Slow read speed for cold data
Papulatus
Hello everyone, this is my first post on this community, recently I built a nas server with freenas, this is my server.
  • Motherboard: SuperMicro X11SSH-LN4F
  • CPU: Intel Xeon E3 1260Lv5
  • RAM: 4x 16 GB Samsung DDR4 ECC 2400T
  • Boot: 2x Samsung FIT Plus 32GB Mirror
  • Hard drives: 8x Seagate IronWolf 4TB RAIDZ2
  • HBA card: none, direct from sata3 port on the motherboard
  • ZIL: Intel Optane 800p 58GB
  • L2ARC: Samsung SM961 256GB
  • NIC: Mellanox ConnectX-3 MCX312B-XCBT active-backup bond
  • PSU: Seasonic 350M1U
  • Case: UNAS NSC-810A
The performance was great, I use it to store all my data, game, photo and everything else, I use samba to store most data and mount it to my windows 10 with 10GB NIC
But I found that the cold data(without cache) read speed over samba like this, it's slow, even seq read, it's only 200MB/s,
but the second time I read it, the speed was great cause of the amazing arc, it's 800MB/s
I guess that my Mellanox NIC is not compatible with FreeNAS, so I used iperf to test the need speed, the result is this:
server side (freenas)
[  5]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[  8]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[ 10]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[ 12]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[ 14]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[ 16]   7.00-8.00   sec   140 MBytes  1.17 Gbits/sec
[ 18]   7.00-8.00   sec   140 MBytes  1.18 Gbits/sec
[ 20]   7.00-8.00   sec   139 MBytes  1.17 Gbits/sec
[SUM]   7.00-8.00   sec  1.09 GBytes  9.40 Gbits/sec
client side (windows 10)
[  4]   8.00-8.72   sec   101 MBytes  1.18 Gbits/sec
[  6]   8.00-8.72   sec   101 MBytes  1.18 Gbits/sec
[  8]   8.00-8.72   sec   101 MBytes  1.18 Gbits/sec
[ 10]   8.00-8.72   sec   100 MBytes  1.17 Gbits/sec
[ 12]   8.00-8.72   sec   100 MBytes  1.17 Gbits/sec
[ 14]   8.00-8.72   sec   100 MBytes  1.17 Gbits/sec
[ 16]   8.00-8.72   sec   100 MBytes  1.17 Gbits/sec
[ 18]   8.00-8.72   sec  99.6 MBytes  1.16 Gbits/sec
[SUM]   8.00-8.72   sec   804 MBytes  9.37 Gbits/sec
It seems that the NIC is not the bottleneck, then I use fio to seq read from the other cold data not in cache, the result is:
fio --filename=3.mkv --sync=1 --rw=read --bs=128k --numjobs=1 --iodepth=32 --group_reporting --name=test --runtime=300
Run status group 0 (all jobs):
   READ: bw=330MiB/s (346MB/s), 330MiB/s-330MiB/s (346MB/s-346MB/s), io=6962MiB (7300MB), run=21099-21099msec
It's about 330MB/s, I'm confusing the speed, is there any problem with my test? Or this speed is normal from a zpool with 8 disks?
In most cases the speed is OK, my arc hit ratio with l2arc is nearly 100%, but when I read from cold data, for example, I use zvol and iscsi target to store my game, every time I want to play the world of the warcraft, I need to copy the whole game data to my local disk to warm the cache, if not it will be a loooooooooong blue line in the game.
Anyone can help me with this case? I've searched the forum but I didn't find any post like this.
Thanks
For any form of RAIDZ, the perfoemance of the VDEV is approximately that of the slowest single disk in the VDEV (in your case of the single VDEV pool, the pool too).
200MB/s reading directly from the disks sounds reasonable in that case.
Of course ARC will improve that when possible.
With only 16GB of RAM, your ARC will struggle to be effective when you also have L2ARC, which stores its tables in ARC, pushing out content.
L2ARC is only considered to be a benefit with more than 64GB of system RAM.
