I had a stripe with 3 disks and I added a 4th disk using the GUI. I follow the procedure showed in the Wiki.
Took some time but the volume shows the total space as of the 4 disks and all data still there. The issue now is that copying files is really slow, like on kb/s from time to time.
I check the status of the volume via ZFS commands and it says that it is ok with no errors.
I was wondering if some rebuild process is going on in the background and while it is happening the performance will be bad.
How can I check it ? Has anyone done that before ?
