Hello all,
I'm on my first experience with TrueNAS and I'm setting up an iSCSI host to run a handful of VMs from. The system is an Inventec dual Xeon E5-2630 @ 2.30GHz with 32GB ram. I have two small SSDs in mirror providing the boot pool and a LSI SAS2308 with a 12-drive backplane holding 8x Enterprise SATA 3TB 7200rpm drives for the primary storage. The NICs are two I350 1GbEs for management/shares and a Mellanox CX312A two-port 10GbE for the iSCSI traffic (failover path setup with two separate IP ranges).
I've not purchased any SLOG drives yet, but from reading the forums, it makes sense to have one for iSCSI setups... Based on what I've read, I calculate 1/8th of my 32GB would be 4GB and the slog should be at least two transactions worth... So I figure 8GB and only 1/4 provisioned for better life. I'm looking at 32GB SSDs so that I can also increase RAM to 64GB and still be good... The system doesn't have any available PCIe slots so NVMe is out. I'm considering a pair of TDK SDE1B032GTKDWBA0ESA0 in mirror which are 32GB SLC SATA SSDs (325MB/s sustained write) and aren't too expensive. They seem to be some hybrid SLC (pSLC? never heard of before) so they only have 20k cycles, but it does indicate "Power Fail Data Safety" and "Power Back-up Circuit".
Thoughts from the experts?
