Hi all,
i'm seeing more and more sync writes on my truenas server and so am planning to try out using a couple of 32Gb Optane M10 M.2 NVMe ssds (MEMPEK1J032GA) in my DL380p and/or Dl560 (both Gen8) als SLOG devs and/or boot volumes. As a test I've temporarily used a standard SATA ssd on the internal 2Gb P420i (yes, with battery backup) to see if performance would benefit, and it made a real difference. So as I'm not totally confident using the onboard RAID (even if "only" as a battery backup slog dev) I'm willing to spend a few euro on testing with the small 32Gb 3D Xpoint NVMe ssds on PCIe adapters. Ideally, I'd use a dual adapter with 2 32Gb M.2 Optanes, one to boot from, one as an slog, but if these don't exist I'll happily just get a single for the slog dev.
Can anybody recommend which PCIe adapters are compatible with the drives I'm looking at? I'm guessing the 32Gb optanes are true NVMe, and not NGFF of even SATA, but I'm unsure how to actually tell which adapters will work for these - I'm confused by the different keys and which ones signify which interfaces actually in use.
Any pointers much appreciated!
TIA
Kai.
TIA
Kai.
