Mastakilla
- Jul 18, 2019
I was trying to put my Intel Optane in use again, but ran into some trouble...
I made 3 partitions on the optane
* 20GB for SLOG
* 16GB for SWAP
* The remainder as non-redundant test pool
I added the SLOG to my encrypted pool with
Which worked well
Then I added the remainder as a pool with
Then exporting the optanepool
And finally importing it again in the GUI.
This also worked, but when I tried enabling compression, I got an error.
So I tried some things, retried some things, rebooted a couple times...
Next I wanted to retry creating and importing the optanepool, but when I exported it via the GUI, I couldn't destroy this specific zpool anymore because it was exported. So I tried selecting the "destroy" checkbox in the GUI when doing the export of optanepool, but that not only destroyed the optanepool partition, but also the SLOG partition.
Now when I try to unlock my encrypted pool, it fails with below error:
I see in the console that it does unlock all HDDs one by one, but then in the end (I guess when it should unlock the SLOG), it fails and rolls back all unlocking steps.
I can't add my newly created SLOG, because the pool is still locked, but I don't know how to unlock it either...
Anyone have suggestion on how to proceed?
* 20GB for SLOG
* 16GB for SWAP
Which worked well
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/local/lib/python3.8/concurrent/futures/process.py", line 239, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 91, in main_worker
    res = MIDDLEWARE._run(*call_args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 45, in _run
    return self._call(name, serviceobj, methodobj, args, job=job)
  File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 39, in _call
    return methodobj(*params)
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 371, in import_pool
    self.logger.error(
  File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 365, in import_pool
    zfs.import_pool(found, new_name or found.name, options, any_host=any_host)
  File "libzfs.pyx", line 1095, in libzfs.ZFS.import_pool
  File "libzfs.pyx", line 1123, in libzfs.ZFS.__import_pool
libzfs.ZFSException: one or more devices is currently unavailable
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/encryption_freebsd.py", line 290, in unlock
    raise e
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/encryption_freebsd.py", line 272, in unlock
    await self.middleware.call('zfs.pool.import_pool', pool['guid'], {
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1203, in _call
    return await self._call_worker(name, *prepared_call.args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1209, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1136, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
libzfs.ZFSException: ('one or more devices is currently unavailable',)I see in the console that it does unlock all HDDs one by one, but then in the end (I guess when it should unlock the SLOG), it fails and rolls back all unlocking steps.
