SiI 3124 Raid Controller
vogelc
Not sure if I am missing something but I know other users are using the SiI3124 controllers in their systems. For some reason do not see the module load or attempt to load. I am using 8.3. The module in question is siis.ko . Any thoughts?
vogelc
Freenas is not seeing the card.
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p4 #0 r241984M: Wed Oct 24 00:57:10 PDT 2012
root@build.ixsystems.com:/usr/home/jpaetzel/8.3.0-RELEASE/os-base/amd64/usr/home/jpaetzel/8.3.0-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Core(TM) i3-2120T CPU @ 2.60GHz (2594.13-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x206a7 Family = 6 Model = 2a Stepping = 7
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x159ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE,AVX>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 8589934592 (8192 MB)
avail memory = 8213368832 (7832 MB)
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Oct 24 2012 00:56:59)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <PCI-PCI bridge> at device 0.0 on pci1
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> at device 0.0 on pci3
pcib5: <ACPI PCI-PCI bridge> irq 19 at device 6.0 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <PCI-PCI bridge> at device 0.0 on pci5
em0: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xf020-0xf03f mem 0xfb100000-0xfb11ffff,0xfb124000-0xfb124fff irq 20 at device 25.0 on pci0
em0: Using an MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:25:90:57:22:59
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfb123000-0xfb1233ff irq 16 at device 26.0 on pci0
ehci0: [ITHREAD]
usbus0: EHCI version 1.0
usbus0: <EHCI (generic) USB 2.0 controller> on ehci0
pcib7: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pci7: <ACPI PCI bus> on pcib7
ql0: <Qlogic ISP 80xx PCI CNA Adapter-Ethernet Function v1.1.30> mem 0xfb400000-0xfb5fffff,0xfb690000-0xfb69ffff irq 16 at device 0.0 on pci7
ql0: [ITHREAD]
ql0: [ITHREAD]
ql0: [ITHREAD]
ql0: [ITHREAD]
ql0: qla_pci_attach: firmware[4.8.22.1319135230]
ql0: Ethernet address: 2c:27:d7:50:52:00
ql1: <Qlogic ISP 80xx PCI CNA Adapter-Ethernet Function v1.1.30> mem 0xfb200000-0xfb3fffff,0xfb680000-0xfb68ffff irq 16 at device 0.1 on pci7
ql1: [ITHREAD]
ql1: [ITHREAD]
ql1: [ITHREAD]
ql1: [ITHREAD]
ql1: qla_pci_attach: firmware[4.8.22.1319135230]
ql1: Ethernet address: 2c:27:d7:50:52:04
pcib8: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
pci8: <ACPI PCI bus> on pcib8
em1: <Intel(R) PRO/1000 Network Connection 7.3.2> port 0xb000-0xb01f mem 0xfb800000-0xfb81ffff,0xfb820000-0xfb823fff irq 16 at device 0.0 on pci8
em1: Using MSIX interrupts with 3 vectors
em1: [ITHREAD]
em1: [ITHREAD]
em1: [ITHREAD]
em1: Ethernet address: 00:25:90:57:22:58
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfb122000-0xfb1223ff irq 23 at device 29.0 on pci0
ehci1: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci1
pcib9: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci9: <ACPI PCI bus> on pcib9
vgapci0: <VGA-compatible display> mem 0xf9000000-0xf9ffffff,0xfb000000-0xfb003fff,0xfa800000-0xfaffffff irq 23 at device 3.0 on pci9
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Cougar Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf000-0xf01f mem 0xfb121000-0xfb1217ff irq 19 at device 31.2 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: [FILTER]
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 10 on acpi0
uart2: [FILTER]
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc97ff,0xc9800-0xcafff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub2: 6 ports with 6 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen1.3: <Dell> at usbus1
uhub4: <Dell USB Keyboard Hub> on usbus1
uhub4: 3 ports with 2 removable, bus powered
ugen1.4: <Dell> at usbus1
ukbd0: <Dell USB Keyboard> on usbus1
kbd2 at ukbd0
uhid0: <Dell USB Keyboard> on usbus1
ugen1.5: <vendor 0x0461> at usbus1
ums0: <vendor 0x0461 USB Optical Mouse, class 0/0, rev 2.00/2.00, addr 5> on usbus1
ums0: 3 buttons and [XYZ] coordinates ID=0
ugen1.6: <Crystalfontz> at usbus1
uftdi0: <Crystalfontz CFA635-USB LCD> on usbus1
ugen0.3: <Winbond Electronics Corp> at usbus0
ums1: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
ums1: 3 buttons and [Z] coordinates ID=0
ukbd1: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0
kbd3 at ukbd1
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD1600AAJS-00Z4A0 01.03E01> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 152627MB (312581808 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 5
ZFS storage pool version 28
FireWire2
Do you have the exact model of your SiI3124?
SiI-3124 comes in TWO flavors: BASE BIOS and RAID BIOS
I remember FreeNAS only support BASE BIOS
Yeah.. I got nothing. That's very bizarre and I have no fix or idea how you might even try to fix it.
FireWire2
I remember now.
Make sure at least a HDD connected
Pay attention at the booting screen
If you see a display such: SATA RAID SiI 3124...
Mean you need to re-flash BIOS of the card to BASE BIOS, then it should work...
If you see SATA LINK... <-- I have not idea :)
