SOLVED SickBeard/SickRage
mav3rek
Here are the SAB logs:
These are both for 1 episode of 1 show.
[11:19:02] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[11:19:02] [INFO]::MAIN: Checking database structure...
[11:19:02] [INFO]::MAIN: Checking if git needs an update
[11:19:02] [INFO]::MAIN: No update needed
[11:19:02] [INFO]::MAIN: nzbToMedia Version:77da142216ba6dc91bb654635d4bd03f13c881e5 Branch:master (FreeBSD 9.3-RELEASE-p8)
[11:19:02] [WARNING]::MAIN: Failed to locate 7zip. Transcosing of disk images and extraction of .7z files will not be possible!
[11:19:02] [INFO]::MAIN: #########################################################
[11:19:02] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[11:19:02] [INFO]::MAIN: Script triggered from SABnzbd
[11:19:02] [INFO]::MAIN: Auto-detected SECTION:SickBeard
[11:19:02] [ERROR]::MAIN: EXTRACTOR: 7zr not found, disabling support for .7z
[11:19:02] [INFO]::MAIN: Extracting /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb.gz to /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__
[11:19:02] [ERROR]::MAIN: EXTRACTOR: Extraction failed for /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb.gz. Result was 126
[11:19:02] [INFO]::MAIN: Calling SickBeard:tv to post-process:Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb
[11:19:02] [INFO]::MAIN: Attempting to auto-detect tv fork
[11:19:02] [INFO]::MAIN: SickBeard:tv fork auto-detection successful ...
[11:19:02] [INFO]::MAIN: SickBeard:tv fork set to sickrage
[11:19:02] [WARNING]::SICKBEARD: No media files found in directory /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb. Processing this as a failed download
[11:19:02] [POSTPROCESS]::SICKBEARD: FAILED: The download failed. Sending 'failed' process request to sickrage branch
[11:19:02] [POSTPROCESS]::SICKBEARD: Processing folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [POSTPROCESS]::SICKBEARD: TV_DOWNLOAD_DIR:
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing Path: /mnt/media/downloads/sabnzbd/incomplete
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing Dirs: [u'Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb']
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing Files: []
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing VideoFiles: []
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing RarContent: []
[11:19:02] [POSTPROCESS]::SICKBEARD: PostProcessing VideoInRar: []
[11:19:02] [POSTPROCESS]::SICKBEARD: Processing folder Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [POSTPROCESS]::SICKBEARD: Failed download detected: (Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb, /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb)
[11:19:02] [POSTPROCESS]::SICKBEARD: Deleted folder: /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [POSTPROCESS]::SICKBEARD: Failed Download Processing succeeded: (Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb, /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb)
[11:19:02] [POSTPROCESS]::SICKBEARD: Successfully processed
[11:19:02] [POSTPROCESS]::SICKBEARD: Deleting failed files and folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [INFO]::MAIN: Deleting /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [ERROR]::MAIN: Unable to delete folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb
[11:19:02] [INFO]::CLEANDIR: Directory /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb has been processed and removed ...
[11:19:02] [INFO]::MAIN: The /usr/local/share/nzbToMedia/nzbToSickBeard.py script completed successfully.
SickBeard: Successfully post-processed Better.Call.Saul.S01E01.1080p.NF.WEBRip.DD5.1.x264-NTb.nzb!
[11:20:30] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[11:20:30] [INFO]::MAIN: Checking database structure...
[11:20:30] [INFO]::MAIN: Checking if git needs an update
[11:20:30] [INFO]::MAIN: No update needed
[11:20:30] [INFO]::MAIN: nzbToMedia Version:77da142216ba6dc91bb654635d4bd03f13c881e5 Branch:master (FreeBSD 9.3-RELEASE-p8)
[11:20:30] [WARNING]::MAIN: Failed to locate 7zip. Transcosing of disk images and extraction of .7z files will not be possible!
[11:20:30] [INFO]::MAIN: #########################################################
[11:20:30] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[11:20:30] [INFO]::MAIN: Script triggered from SABnzbd
[11:20:30] [INFO]::MAIN: Auto-detected SECTION:SickBeard
[11:20:30] [ERROR]::MAIN: EXTRACTOR: 7zr not found, disabling support for .7z
[11:20:30] [INFO]::MAIN: Extracting /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb.gz to /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__
[11:20:30] [ERROR]::MAIN: EXTRACTOR: Extraction failed for /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb/__ADMIN__/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb.gz. Result was 126
[11:20:30] [INFO]::MAIN: Calling SickBeard:tv to post-process:Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb
[11:20:30] [INFO]::MAIN: Attempting to auto-detect tv fork
[11:20:30] [INFO]::MAIN: SickBeard:tv fork auto-detection successful ...
[11:20:30] [INFO]::MAIN: SickBeard:tv fork set to sickrage
[11:20:30] [WARNING]::SICKBEARD: No media files found in directory /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb. Processing this as a failed download
[11:20:30] [POSTPROCESS]::SICKBEARD: FAILED: The download failed. Sending 'failed' process request to sickrage branch
[11:20:30] [POSTPROCESS]::SICKBEARD: Processing folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [POSTPROCESS]::SICKBEARD: TV_DOWNLOAD_DIR:
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing Path: /mnt/media/downloads/sabnzbd/incomplete
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing Dirs: [u'Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb']
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing Files: []
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing VideoFiles: []
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing RarContent: []
[11:20:30] [POSTPROCESS]::SICKBEARD: PostProcessing VideoInRar: []
[11:20:30] [POSTPROCESS]::SICKBEARD: Processing folder Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [POSTPROCESS]::SICKBEARD: Failed download detected: (Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb, /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb)
[11:20:30] [POSTPROCESS]::SICKBEARD: Deleted folder: /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [POSTPROCESS]::SICKBEARD: Failed Download Processing succeeded: (Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb, /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb)
[11:20:30] [POSTPROCESS]::SICKBEARD: Successfully processed
[11:20:30] [POSTPROCESS]::SICKBEARD: Deleting failed files and folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [INFO]::MAIN: Deleting /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [ERROR]::MAIN: Unable to delete folder /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb
[11:20:30] [INFO]::CLEANDIR: Directory /mnt/media/downloads/sabnzbd/incomplete/Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb has been processed and removed ...
[11:20:30] [INFO]::MAIN: The /usr/local/share/nzbToMedia/nzbToSickBeard.py script completed successfully.
SickBeard: Successfully post-processed Better.Call.Saul.S01E01.720p.NF.WEBRip.DD5.1.x264-NTb.nzb!
Joshua Parker Ruehlig
Looks like it couldn't find the video files and sickrage marked them as failed downloads. Did sabnzbd say anything about ithe download failing?
Are these old files you are downloading, alot of times they are taken down off usenet after a few days =/
mav3rek
SAB just says "Aborted could not be completed" and these files should not be that old. This show has only been on 1 week.
well, that's your problem. you might have everything setup properly but if the file isn't available on your usenet server there's nothing I could help you with.
Alot of shows are taken down within 1 day or two. Some files get posted with fake names which usually don't get taken down, but you'd need an usenet indexer that can understand these.
mav3rek
I use Usenetserver and have an account there, but I'm not sure about much anything else.
So I can't go back and get these shows?
Only going forward I can get new ones as they are posted?
What are my options to get these previous episodes?
Thanks for all your help again.
I also use usenetserver, some people say having a backup one located in another coutry helps but I havent done that myself.
Torrents are more reliable for older stuff but there's an obvious risk.
mav3rek
Ok, so do you think I should switch to torrents as the main search for now until I get caught up on the shows I want and then switch back to nzb for new episodes?
up to you, there's more of a risk, not as consistent quality, but it does have more reliability for more popular shows.
mav3rek
Issue has been resolved. Thanks for the help! Turns out I was trying to use it incorrectly more or less.
Glad it works! Yeah, it's somewhat confusing, that's why I just left it default, lol.
leemajors
Ok, I have been literally working on this for 4 straight days....
I have searched, and searched and searched.
I have erased everything and done 3 or 4 complete fresh reinstalls of FreeNAS as a whole.
I am about to go insane.....
I want to setup SickBeard or SickRage with SABnzbd and Plex to automatically get the shows, put them in the right folders, and live a happy long life.
Since I blew everything up and have started fresh, this is exactly what I did:
Fresh install of FreeNAS.
Checked for update and ran/installed it.
Installed Plex via plugin menu
Installed SickBeard via plugin menu
Installed SABnzbd via plugin menu
I went through and configured SickBeard with my usenet account, setup SABnzbd with the api, etc. standard stuff.
When I try to search for a TV Show in SickBeard (I tried sickrage too just in case), I get no results.
Doesn't matter what the show is, no results are returned.
Here is the error log from SickBeard:
Unable to get URL: http://thetvdb.com/api/GetSeries.php?seriesname=xxxxxxx
Any help at all would be very much appreciated.
Thanks,
Mav
can anyone help me install sickbeard and sabnzd please im frustrated
I'm not sure why you're posting to this thread. Create a new topic describing your issue.
leemajors
let me ask you a question to make sure im in the right forum
i have a ready nas box im trying to install sickbeard and sabnzid
am i in the right fourm
thx
thx
what's a ready nas? sounds like you are either a troll or confused.
leemajors
leemajors
im looking for installation of the above apps i mentioned
there third party apps
i Googled and i seen the person was having the same issues
1) his issues have nothing to do with plugin installation.
2) your running a different OS then what this forum supports.
