Sickbeard POSTPROCESSER: error 13 : Permission denied
chris pucknell
Hey
Sickbeard is having a little trouble with the post-processing. I'm getting the following in the error log over and over and over again:
2015-09-01 21:06:42 POSTPROCESSER :: Exception generated in thread POSTPROCESSER: error 13 : Permission denied
and when I try to do a manual post processing through sickbeard, I get this:
500 Internal Server Error
The server encountered an unexpected condition which prevented it from fulfilling the request.
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/cherrypy/_cprequest.py", line 660, in respond
    response.body = self.handler()
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/cherrypy/lib/encoding.py", line 193, in __call__
    self.body = self.oldhandler(*args, **kwargs)
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/cherrypy/_cpdispatch.py", line 25, in __call__
    return self.callable(*self.args, **self.kwargs)
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/sickbeard/webserve.py", line 1429, in processEpisode
    result = processTV.processDir(dir, nzbName, method=method, pp_options=pp_options)
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/sickbeard/processTV.py", line 148, in processDir
    returnStr += processDir(cur_folder, nzbName=parent_nzbName, recurse=True, method=method, pp_options=pp_options)
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/sickbeard/processTV.py", line 119, in processDir
    fileList = ek.ek(os.listdir, dirName)
  File "/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/sickbeard/encodingKludge.py", line 62, in ek
    result = func(*[callPeopleStupid(x) if type(x) in (str, unicode) else x for x in args])
OSError: [Errno 13] Permission denied: '/media/Downloads/incomplete/Aqua.Unit.Patrol.Squad.1.S08E01.Allen.Pt.1.1080p.WEB-DL.AAC2.0.H264-iT00NZ/
I'm a bit at see here. My downloads folder has been made accessible to the jail, seems to be a recent-ish problem; has worked fine in the past.
I've seen elsewhere that making a user for the plugin can help get around these permission issues, but i've not idea where to start making these users!
Any help will be greatly appreciated :D
Joshua Parker Ruehlig
it looks like the file you are trying to post-process is in /media/Downloads/incomplete, here are some questions.
* why are you post-processing in a folder named incomplete? sickbeard should be post-processing completed and processed downloads from sabnzbd/transmission
* what are the permissions of this folder 'ls -l /media/Downloads' 'ls -l /media/Downloads/incomplete'
* what folder should sickbeard be moving files to?
* what are the permissions of this folder 'ls -l /path/to/folder'
chris pucknell
Hey
My incomplete downloads are stored as a sub-directory of the downloads folder xD I guess I could change that if it's causing trouble, or can I just alter the permissions to the sub-folder?
Sickbeard should be moving the files to another zpool(is that the right term?) '/mnt/MainArray/Media/TV_Shows' I believe. I'll have to check those permissions out when I get back!
OK, sickbeard shouldn't be post-processing incomplete downloads, only ones that are complete.
chris pucknell
okay i've checked it out, there are a bazillion files in the downloads dir, everything (with a handful of exceptions) has these permissions:
drwxrwxrwx 270 xargon xargon 278 Sep 3 16:50 Downloads
xargon is my main user account.
I discovered Sickbeard was set to NOT remove the files after relocation. So that kind of explains why they are all still in there, I guess. But I would think that after changing that setting it would start to clean up the dir by itself :/
SickBeard should be moving this stuff into '/Media/TV_Series', otherwise known as '/mnt/MainArray/Media/TV_Series' outside of the jail.
the TV_Series dir has these permissions:
drwxrwxr-x+ 59 xargon nogroup 59 Aug 20 21:35 ./
drwxrwxr-x+ 12 xargon xargon 13 May 14 18:58 ../
drwxrwxr-x+ 2 xargon nogroup 116 Aug 24 09:03 Aqua Teen Hunger Force Forever/
drwxrwxr-x+ 2 xargon nogroup 2 Feb 6 2015 Band of Brothers (2001)/
etc...
chris pucknell
news just in:
2015-09-03 17:03:52 POSTPROCESSER :: Failed to set permission for /media/TV_Series/Mr. Robot/Mr. Robot - 1x10 - eps1.9_zer0-day.avi.nzb to 664
etc...
OK, what's the UID of your xargon user?
Your TV_Series folder only allows the owner and group members to write in there. Read and implement a solution from here.
https://forums.freenas.org/index.ph...plugins-write-permissions-to-your-data.27273/
chris pucknell
xargon UID: 1001
Ah i've seen this thread before, I think I tried and failed :/
So I can add group permissions to the plugin user inside the jail. How do I find out what this user is?
chris pucknell
okay i've implemented 'Solution 2' from inside the jail
pw useradd -n xargon -u 1001 -d /nonexistent -s /usr/sbin/nologin
service sickbeard onestop
chown -R xargon:xargon /var/db/sickbeard
sysrc 'sickbeard_user=xargon'
service sickbeard start
Pretty sure i've done this in the past!
just ran a manual post processing and it has given me the same '500 internal error' biz :/
can you show the actual error.
also the output of 'ps aux' in the jail
chris pucknell
root@sickbeard_1:/ # ps aux
USER     PID %CPU %MEM    VSZ    RSS TT  STAT STARTED    TIME COMMAND
root    8983  0.0  0.0  12092   1864 ??  IsJ   4:48PM 0:00.01 /usr/sbin/syslogd
root    9043  0.0  0.0  14188   1856 ??  IsJ   4:48PM 0:00.01 /usr/sbin/cron -s
root    9267  0.0  0.2 150752  39532 ??  IJ    4:48PM 0:02.56 /usr/pbi/sickbeard
xargon 19563  0.0  0.6 262128 101372 ??  SJ    5:32PM 0:56.27 /usr/pbi/sickbeard
root   28759  0.0  0.0  17572   3408  0  SsJ   7:19PM 0:00.01 /bin/csh
root   28761  0.0  0.0  16300   2140  0  R+J   7:19PM 0:00.00 ps aux
the manual post-processing error:
Here is an extract of the error log, in all it's horrible glory. Brace yourself:
2015-09-03 19:28:47 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.avi to 664
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.sample.avi to 664
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.sub to 664
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.nfo-orig to 664
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.idx to 664
2015-09-03 19:28:46 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x14 - Spirit Journey Formation Anniversary.sfv to 664
2015-09-03 19:28:46 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:44 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.sample.avi to 664
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.nfo-orig to 664
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.idx to 664
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.sfv to 664
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.sub to 664
2015-09-03 19:28:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.subs.sfv to 664
2015-09-03 19:28:42 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x12 - Total Re-Carl.avi to 664
2015-09-03 19:28:35 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:34 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 10x02 - The Dudies.mkv to 664
2015-09-03 19:28:34 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 10x02 - The Dudies.unknown.ignore to 664
2015-09-03 19:28:34 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:30 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.avi to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.idx to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.sfv to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.subs.sfv to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.sample.avi to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.nfo-orig to 664
2015-09-03 19:28:29 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x10 - Super Trivia.sub to 664
2015-09-03 19:28:27 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:26 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x12 - Antenna.avi to 664
2015-09-03 19:28:26 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x12 - Antenna.sfv to 664
2015-09-03 19:28:26 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x12 - Antenna.nfo-orig to 664
2015-09-03 19:28:26 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:24 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:23 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.subs.sfv to 664
2015-09-03 19:28:23 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.sample.avi to 664
2015-09-03 19:28:23 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:22 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.avi to 664
2015-09-03 19:28:22 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.nfo-orig to 664
2015-09-03 19:28:22 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.sfv to 664
2015-09-03 19:28:22 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.idx to 664
2015-09-03 19:28:22 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x08 - Super Squatter.sub to 664
2015-09-03 19:28:16 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:15 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:14 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 10x06 - Skins.mkv to 664
2015-09-03 19:28:14 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 10x06 - Skins.unknown.ignore to 664
2015-09-03 19:28:11 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:10 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:09 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 9x05 - The Granite Family.mkv to 664
2015-09-03 19:28:09 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 9x05 - The Granite Family.srr to 664
2015-09-03 19:28:09 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 9x05 - The Granite Family.nfo-orig to 664
2015-09-03 19:28:09 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 9x05 - The Granite Family.sfv to 664
2015-09-03 19:28:09 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 9x05 - The Granite Family.unknown.ignore to 664
2015-09-03 19:28:07 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:06 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:04 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x04 - Star Studded Xmas Spectacular (2).avi to 664
2015-09-03 19:28:04 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x04 - Star Studded Xmas Spectacular (2).sample.avi to 664
2015-09-03 19:28:04 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x04 - Star Studded Xmas Spectacular (2).nfo-orig to 664
2015-09-03 19:28:04 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x04 - Star Studded Xmas Spectacular (2).sfv to 664
2015-09-03 19:28:03 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:02 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x10 - Moonajuana.sample.avi to 664
2015-09-03 19:28:02 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x10 - Moonajuana.sfv to 664
2015-09-03 19:28:02 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:28:01 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x10 - Moonajuana.avi to 664
2015-09-03 19:28:01 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x10 - Moonajuana.nfo-orig to 664
2015-09-03 19:27:58 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:57 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 11x01 - Mouth Quest.nfo-orig to 664
2015-09-03 19:27:57 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:56 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 11x01 - Mouth Quest.mkv to 664
2015-09-03 19:27:56 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 11x01 - Mouth Quest.sfv to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.sample.avi to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.sub to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.subs.sfv to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.nfo-orig to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.sfv to 664
2015-09-03 19:27:55 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.idx to 664
2015-09-03 19:27:55 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:53 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x04 - Super Computer.avi to 664
2015-09-03 19:27:52 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:51 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x05 - Dickesode.sfv to 664
2015-09-03 19:27:51 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x05 - Dickesode.sample.avi to 664
2015-09-03 19:27:51 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:50 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x05 - Dickesode.avi to 664
2015-09-03 19:27:50 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x05 - Dickesode.nfo-orig to 664
2015-09-03 19:27:49 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:48 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:47 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 1x06 - Space Conflict From Beyond Pluto.avi to 664
2015-09-03 19:27:47 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 1x06 - Space Conflict From Beyond Pluto.nzb to 664
2015-09-03 19:27:45 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:44 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x03 - Star Studded Xmas Spectacular (1).unknown.ignore to 664
2015-09-03 19:27:44 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x03 - Star Studded Xmas Spectacular (1).avi to 664
2015-09-03 19:27:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x03 - Star Studded Xmas Spectacular (1).sample.avi to 664
2015-09-03 19:27:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x03 - Star Studded Xmas Spectacular (1).nfo-orig to 664
2015-09-03 19:27:43 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 4x03 - Star Studded Xmas Spectacular (1).sfv to 664
2015-09-03 19:27:41 CP Server Thread-7 :: PLEXNotifier: coercing to Unicode: need string or buffer, instance found
2015-09-03 19:27:40 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x06 - Super Spore.sub to 664
2015-09-03 19:27:40 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x06 - Super Spore.sfv to 664
2015-09-03 19:27:40 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x06 - Super Spore.idx to 664
2015-09-03 19:27:40 CP Server Thread-7 :: Failed to set permission for /media/TV_Series/Aqua Teen Hunger Force Forever/Aqua Teen Hunger Force Forever - 2x06 - Super Spore.subs.sfv to 664
so sickbeard is copying the file over right? how about deleting it from your download directory?
can you show the output of..
ls -l /media/TV_Series
chris pucknell
TV_Series output:
drwxrwxr-x+ 11 xargon nogroup 14 Feb 6 2015 Star Trek - Deep Space 9
drwxrwxr-x+ 10 xargon nogroup 10 Jan 8 2014 Star Trek - The Next Generation
drwxrwxr-x+ 6 xargon nogroup 6 Dec 31 2013 Star Trek - The Original Series
incomplete dir output:
drwxrwxrwx 3 xargon xargon 23 Jul 29 12:14 orange.is.the.new.black.s02e12.108
0p.bluray.x264-rovers
drwxrwxrwx 3 xargon xargon 48 Jul 29 12:35 orange.is.the.new.black.s02e13.108
drwxrwxrwx 3 xargon xargon 5 Jul 29 08:08 orange.is.the.new.black.s03e05.108
0p.webrip.x264-2hd
chris pucknell
yeah sickbeard seems to be copying them over but not deleting them, and all these errors about setting the permission to 664... isn't the permission supposed to be 777? or something similar?
Im not sure what sickbeard sets it to. I'm guessing it tries to match the parent directory.
not sure why SB isn't deleting them. maybe your post-process settings.
OK, I assume the problem is related to your windows permissions. I don't know anything about these except they complicate things further.
https://forums.freenas.org/index.php?threads/sickbeard-failed-to-set-permission-error.36942/
chris pucknell
have got everything set to unix permissions because of just that xD
I have removed the offending incomplete dir and created a seperate zpool. It's no longer throwing up this '500 Internal Server Error' page, but still doesn't seem to be removing anything from the downloads dir... the processing log states that after sickbeard determines the file has already been moved, it takes no further action. Perhaps this is an intentional feature!
Well thanks for all your help ;) I'm gonna bite the bullet and wade through all the accumulated garbage!
there's a setting in SB to move/copy/link so you can change this behavior
chris pucknell
oh yeah I believe this is the setting, just doesn't seem to be doing it for me :/
perhaps there is some kind of evil config file problem...
INCSlayer
I believe he was talking about this setting:
