I'm still working on getting everything to work after I set up a new SB/SAB/Couchpotato... Jail. Last night i noticed that SAB failed to post process everything and send it to Sickbeard. It looks like the files were downloaded fine and it did not delete them (they were still in the complete folder). I followed the guide at https://www.jruehlig.com/wordpress/installation-configuration-of-freenas-plugins/ to set it up. I know jruehlig is a regular around here, i'm hoping he might have an idea what is going wrong.
Here is the script log for one of the failures.
           [20:56:02] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[20:56:02] [INFO]::MAIN: Checking database structure...
[20:56:02] [INFO]::MAIN: Checking if git needs an update
[20:56:02] [INFO]::MAIN: No update needed
[20:56:02] [INFO]::MAIN: nzbToMedia Version:1cd64053b0da1d351bb6af392e1ebb904c6b6ce2 Branch:master (FreeBSD 9.1-RELEASE)
[20:56:02] [WARNING]::MAIN: Failed to locate 7zip. Transcosing of disk images and extraction of .7z files will not be possible!
[20:56:02] [INFO]::MAIN: #########################################################
[20:56:02] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[20:56:02] [INFO]::MAIN: Script triggered from SABnzbd 0.7.17+
[20:56:02] [INFO]::MAIN: Auto-detected SECTION:SickBeard
[20:56:02] [INFO]::MAIN: Calling SickBeard:tv to post-process:Haven.S05E17.720p.HDTV.x264-FLEET.nzb
[20:56:02] [INFO]::MAIN: Attempting to auto-detect tv fork
[20:56:02] [INFO]::MAIN: SickBeard:tv fork auto-detection found custom params {}
[20:56:02] [INFO]::MAIN: SickBeard:tv fork set to custom
[20:56:02] [INFO]::MAIN: FLATTEN: Flattening directory: /mnt/media/downloads/sabnzbd/complete/tv/Haven.S05E17.720p.HDTV.x264-FLEET
[20:56:02] [INFO]::TRANSCODER: Checking [Haven.S05E17.720p.HDTV.x264-FLEET.mkv] for corruption, please stand by ...
[20:56:03] [INFO]::TRANSCODER: SUCCESS: [Haven.S05E17.720p.HDTV.x264-FLEET.mkv] has no corruption.
[20:56:03] [POSTPROCESS]::SICKBEARD: SUCCESS: The download succeeded, sending a post-process request
[20:56:03] [POSTPROCESS]::SICKBEARD: <!DOCTYPE html>
[20:56:03] [POSTPROCESS]::SICKBEARD: <html>
[20:56:03] [POSTPROCESS]::SICKBEARD:     <head>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta charset="utf-8">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="robots" content="noindex, nofollow">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta http-equiv="X-UA-Compatible" content="IE=edge">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="viewport" content="width=device-width">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <!-- These values come from css/dark.css and css/light.css -->
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="theme-color" content="#15528F">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <title>SickRage - BRANCH:[master] - Login</title>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <!--[if lt IE 9]>
[20:56:03] [POSTPROCESS]::SICKBEARD:             <script src="https://oss.maxcdn.com/html5shiv/3.7.2/html5shiv.min.js"></script>
[20:56:03] [POSTPROCESS]::SICKBEARD:             <script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <![endif]-->
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="msapplication-TileColor" content="#FFFFFF">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="msapplication-TileImage" content="/sickrage/images/ico/favicon-144.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta name="msapplication-config" content="/sickrage/css/browserconfig.xml">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="srRoot" data-content="/sickrage">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="themeSpinner" data-content="-dark">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="anonURL" data-content="http://dereferer.org/?">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.ANIME_SPLIT_HOME" data-content="False">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.COMING_EPS_LAYOUT" data-content="banner">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.COMING_EPS_SORT" data-content="date">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.DATE_PRESET" data-content="%a, %b %d, %Y">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.FILTER_ROW" data-content="0">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.FUZZY_DATING" data-content="0">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.HISTORY_LAYOUT" data-content="detailed">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.HOME_LAYOUT" data-content="simple">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.POSTER_SORTBY" data-content="name">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.POSTER_SORTDIR" data-content="1">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.ROOT_DIRS" data-content="0|/mnt/media/videos/tvshows">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.SORT_ARTICLE" data-content="1">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.TIME_PRESET" data-content="%I:%M %p">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <meta data-var="sickbeard.TRIM_ZERO" data-content="0">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="shortcut icon" href="/sickrage/images/ico/favicon.ico">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" sizes="16x16 32x32 64x64" href="/sickrage/images/ico/favicon.ico">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="196x196" href="/sickrage/images/ico/favicon-196.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="160x160" href="/sickrage/images/ico/favicon-160.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="96x96" href="/sickrage/images/ico/favicon-96.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="64x64" href="/sickrage/images/ico/favicon-64.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="32x32" href="/sickrage/images/ico/favicon-32.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="icon" type="image/png" sizes="16x16" href="/sickrage/images/ico/favicon-16.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="152x152" href="/sickrage/images/ico/favicon-152.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="144x144" href="/sickrage/images/ico/favicon-144.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="120x120" href="/sickrage/images/ico/favicon-120.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="114x114" href="/sickrage/images/ico/favicon-114.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="76x76" href="/sickrage/images/ico/favicon-76.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" sizes="72x72" href="/sickrage/images/ico/favicon-72.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="apple-touch-icon" href="/sickrage/images/ico/favicon-57.png">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/lib/bootstrap.min.css?92511"/>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/browser.css?92511" />
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/lib/jquery-ui-1.10.4.custom.min.css?92511" />
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/lib/jquery.qtip-2.2.1.min.css?92511"/>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/style.css?92511"/>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/dark.css?92511" />
[20:56:03] [POSTPROCESS]::SICKBEARD:         <link rel="stylesheet" type="text/css" href="/sickrage/css/print.css?92511" />
[20:56:03] [POSTPROCESS]::SICKBEARD:     </head>
[20:56:03] [POSTPROCESS]::SICKBEARD:     <body>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <nav class="navbar navbar-default navbar-fixed-top hidden-print" role="navigation">
[20:56:03] [POSTPROCESS]::SICKBEARD:             <div class="container-fluid">
[20:56:03] [POSTPROCESS]::SICKBEARD:                 <div class="navbar-header">
[20:56:03] [POSTPROCESS]::SICKBEARD:                     <button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#bs-example-navbar-collapse-1">
[20:56:03] [POSTPROCESS]::SICKBEARD:                         <span class="sr-only">Toggle navigation</span>
[20:56:03] [POSTPROCESS]::SICKBEARD:                         <span class="icon-bar"></span>
[20:56:03] [POSTPROCESS]::SICKBEARD:                     </button>
[20:56:03] [POSTPROCESS]::SICKBEARD:                     <a class="navbar-brand" href="/sickrage/home/" title="SickRage"><img alt="SickRage" src="/sickrage/images/sickrage.png" style="height: 50px;" class="img-responsive pull-left" /></a>
[20:56:03] [POSTPROCESS]::SICKBEARD:                 </div>
[20:56:03] [POSTPROCESS]::SICKBEARD:                 </div><!-- /.navbar-collapse -->
[20:56:03] [POSTPROCESS]::SICKBEARD:             </div><!-- /.container-fluid -->
[20:56:03] [POSTPROCESS]::SICKBEARD:         </nav>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <div id="contentWrapper">
[20:56:03] [POSTPROCESS]::SICKBEARD:             <div id="content">
[20:56:03] [POSTPROCESS]::SICKBEARD: <div class="login">
[20:56:03] [POSTPROCESS]::SICKBEARD:     <form action="" method="post">
[20:56:03] [POSTPROCESS]::SICKBEARD:         <h1>SickRage</h1>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <div class="ctrlHolder"><input class="inlay" name="username" type="text" placeholder="Username" autocomplete="off" /></div>
[20:56:03] [POSTPROCESS]::SICKBEARD:         <div class="ctrlHolder"><input class="inlay" name="password" type="password" placeholder="Password" autocomplete="off" /></div>
[20:56:03] [POSTPROCESS]::SICKBEARD:             <label class="remember_me" title="for 30 days"><input class="inlay" id="remember_me" name="remember_me" type="checkbox" value="1"checked="checked" /> Remember me</label>
[20:56:03] [POSTPROCESS]::SICKBEARD:             <input class="button" name="submit" type="submit" value="Login" />
[20:56:03] [POSTPROCESS]::SICKBEARD:     </form>
[20:56:03] [POSTPROCESS]::SICKBEARD:             </div> <!-- /content -->
[20:56:03] [POSTPROCESS]::SICKBEARD:         </div> <!-- /contentWrapper -->
[20:56:03] [POSTPROCESS]::SICKBEARD:     </body>
[20:56:03] [POSTPROCESS]::SICKBEARD: </html>
[20:56:03] [ERROR]::MAIN: A problem was reported in the /usr/local/share/nzbToMedia/nzbToSickBeard.py script.
SickBeard: Failed to post-process - Returned log from SickBeard was not as expected.!
