Sickbeard Post Processing "Unable to figure out what folder to process."
Seth Tipton
I'm on a freenas box and I'm having a problem configuring my TV Download Dir in sickbeard. Sabnzbd recently became corrupted so I had to do a fresh install and lost my configuration. From what I can tell, the autoprocesstv script is running like it should. In SB, my TV Download Dir is set to "/media/Downloaded" and when I click on browse I find all of my old TV files.
http://i.imgur.com/F5VZDFk.png
However when the download completes in sabnzbd I get this error "Unable to figure out what folder to process. If your downloader and Sick Beard aren't on the same PC make sure you fill out your TV download dir in the config."
http://i.imgur.com/RZO2NN9.png
Here is my jail storage setup in freenas (customplugin_1 is sabnzbd)
http://i.imgur.com/lVTvX8k.png
FlyingPersian
I'm experiencing the same with SickRage. rtorrent downloads the file, runs nzbToMedia, which calls SickRage for PostProcessing, but that ends with the same error. Manual PostProcessing works fine.
