shutdown -r of bhyve guest leaves VM in "STOPPED" state
Patrick M. Hausen
FreeBSD (or Linux, doesn't matter) UEFI boot VM in bhyve/FreeNAS 11. shutdown -r now in guest. Clean shutdown, but instead of coming up again the machine is left in the "STOPPED" state.
Bug or feature?
Thanks,
Patrick
D
dlavigne
Guest
Do you get the same issue if you use the VM's restart button?
Patrick M. Hausen
I rarely use Stop or Restart from the UI, because that causes an unclean shutdown of the VM. And to answer your question: yes.
I just tried it to verify, then booted single user for the necessary fsck, then tried this:
# reboot
Nov 28 20:20:39 init: single user shell terminated.
Waiting (max 60 seconds) for system process `vnlru' to stop...done
Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining...0 0 0 0 0 0 0 0 0 done
All buffers synced.
Uptime: 29s
That's it. No more console output, machine "STOPPED" in the UI.
The machine has got the two devices, who's config I attached. I don't need VGA/VNC for machines running FreeBSD or Linux. The guest OS is RELENG_10_4, but machines with RELENG_11_1 or Ubuntu behave exactly the same way.
Patrick
D
dlavigne
Guest
In that case, please create a bug report at bugs.freenas.org and post the issue number here.
Patrick M. Hausen
