- Nov 25, 2013
Hi all,
I just installed an OPNsense in bhyve with two network interfaces passed through. This part in general worked suprisingly easy and well given the heat that bhyve frequently receives.
I had two issues, one I could solve myself:
Kind regards,
Patrick
shutdown -p nowor shutdown via OPNsense UI or "STOP" in the TrueNAS UI would shut down the virtual machine to the point that all filesystems were unmounted cleanly, but the machine would not "power off. It would hang with the last message being "ix1 changed state to DOWN".
I could fix that one withhw.efi.poweroff=0inside the VM's OS.- Unfortunately that does not fix things for
shutdown -r now, not even forreboot. Like above the system shuts down but then the final reset does not happen and the VM stays in that state until I click "POWER OFF" in the TrueNAS UI and then "START".
I tried each possible combination of values forhw.acpi.handle_rebootandhw.acpi.disable_on_rebootwithout anything changing.
Kind regards,
Patrick
