scotrod
- Apr 30, 2021
Hi. I am trying to understand whether I should trust TrueNAS Scale smartctl tool or Scrutiny (https://github.com/AnalogJ/scrutiny) for S.M.A.R.T results.
I recently replaced a failing boot disk (SSD) with another - one of my old ones. I performed both SHORT and LONG S.M.A.R.T tests for my new boot disk using smartctl and TrueNAS Scale GUI said that everything is fine. Upon running `smartctl -a /dev/sde` I am getting the following output:
For the same disk in Scrutiny however, I get:
First of all, this disk should have waaay more than 36 days of uptime - this was my boot drive on my old computer for years. No way that data is true. So, either the disk is going bad and the S.M.A.R.T data is not really correct, or one of these tools is not reading it correcly.
root@truenas[~]# smartctl -a /dev/sdf
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Model Family: Intel 540 Series SSDs
Device Model: INTEL SSDSC2KW120H6
Serial Number: CVLT62000C7C120GGN
LU WWN Device Id: 5 5cd2e4 14cbfa88c
Firmware Version: LSBG200
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic
ATA Version is: ACS-3 (minor revision not indicated)
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Apr 27 19:24:08 2023 EEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 15) minutes.
SCT capabilities: (0x0039) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 373
9 Power_On_Hours_and_Msec 0x0032 100 100 000 Old_age Always - 870h+00m+00.000s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1312
170 Available_Reservd_Space 0x0033 098 098 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 010 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 010 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 34
183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 51415
190 Airflow_Temperature_Cel 0x0032 038 051 000 Old_age Always - 38 (Min/Max 26/51)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 34
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 383579
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 0
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 0
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 0
232 Available_Reservd_Space 0x0033 059 059 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 081 081 000 Old_age Always - 0
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 383579
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 347127
249 NAND_Writes_1GiB 0x0032 100 100 000 Old_age Always - 7373
252 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 80
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 0
Warning: ATA Specification requires self-test log structure revision number = 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 70403103932424 70403103932424 Not_testing
2 70403103932424 70403103932424 Not_testing
3 70403103932424 70403103932424 Not_testing
4 70403103932424 70403103932424 Not_testing
5 70403103932424 70403103932424 Not_testing
Selective self-test flags (0x4008):
root@truenas[~]#
