Hi, I know these types of questions have been asked thousands of times before but I have a scenario I've not seen before.
I have a pool with some aging 6TB disks - they've been up for around 6 years so are likely nearing their end. However, I launched the WebUI a couple of weeks ago and noticed the pool had a degraded status. I checked the disks and noticed one of the 6TB disks had failed both a short and long SMART test. I ran the tests again to confirm and noticed this attribute:
I then purchased two 16TB drives to replace this mirror and installed them into the server, but upon reboot, the pool status went back to healthy.
I've run multiple short and long tests on the failing drive and the short tests now pass and the long test continues to fail - the attributes have not changed.
It's been two weeks now while I burn in the new disks the pool status remains healthy without error...which is puzzling since there had been an error a couple of weeks ago. I've also checked the other drive in the mirror and that now also has a Multi_Zone_Error_Rate of 1 while both long and short test pass as success
Neither drive has pending sectors or offline uncorrectable.
Are these drives actually dead and should I continue with my plan to replace them? Here are the smart reports for each drive:
As always any help is greatly appreciated.
Thanks
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 3
~ smartctl =a /dev/sdc smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.142+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Serial Number: WD-WXB1HB4M834T LU WWN Device Id: 5 0014ee 262637a68 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Aug 3 11:41:45 2023 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 249) Self-test routine in progress... 90% of test remaining. Total time to complete Offline data collection: ( 4244) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 696) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 194 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 206 197 021 Pre-fail Always - 8691 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 795 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 028 028 000 Old_age Always - 52697 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 682 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 156 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1159 194 Temperature_Celsius 0x0022 121 093 000 Old_age Always - 31 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 52651 - # 2 Short offline Completed without error 00% 52590 - # 3 Short offline Completed without error 00% 52426 - # 4 Short offline Completed without error 00% 52258 - # 5 Short offline Completed without error 00% 52090 - # 6 Short offline Completed without error 00% 51922 - # 7 Extended offline Completed without error 00% 51911 - # 8 Short offline Completed without error 00% 51754 - # 9 Short offline Completed without error 00% 51587 - #10 Short offline Completed without error 00% 51419 - #11 Short offline Completed without error 00% 51251 - #12 Extended offline Completed without error 00% 51193 - #13 Short offline Completed without error 00% 51087 - #14 Short offline Completed without error 00% 50916 - #15 Short offline Completed without error 00% 50748 - #16 Short offline Completed without error 00% 50580 - #17 Extended offline Completed without error 00% 50449 - #18 Short offline Completed without error 00% 50412 - #19 Short offline Completed without error 00% 50248 - #20 Short offline Completed without error 00% 50077 - #21 Short offline Completed without error 00% 49909 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
~ smartctl -a /dev/sdd smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.142+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD60EFRX-68L0BN1 Serial Number: WD-WX11DA5NDJUU LU WWN Device Id: 5 0014ee 20cd773d8 Firmware Version: 82.00A82 User Capacity: 6,001,175,126,016 bytes [6.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5700 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Aug 3 11:42:31 2023 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 2624) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 680) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 190 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 206 197 021 Pre-fail Always - 8658 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 797 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 028 028 000 Old_age Always - 52979 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 684 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 153 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1177 194 Temperature_Celsius 0x0022 122 093 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 3 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 52979 70528392 # 2 Extended offline Completed: read failure 90% 52920 70528392 # 3 Short offline Completed without error 00% 52872 - # 4 Extended offline Completed: read failure 90% 52799 70528392 # 5 Extended offline Completed: read failure 90% 52732 70528392 # 6 Short offline Completed without error 00% 52731 - # 7 Short offline Completed: read failure 10% 52708 70529520 # 8 Short offline Completed: read failure 10% 52540 70529520 # 9 Extended offline Completed: read failure 90% 52493 70528392 #10 Short offline Completed: read failure 10% 52492 70529520 #11 Short offline Completed: read failure 10% 52372 70529520 #12 Short offline Completed without error 00% 52205 - #13 Extended offline Completed: read failure 90% 52180 70528264 #14 Short offline Completed without error 00% 52036 - #15 Short offline Completed without error 00% 51869 - #16 Short offline Completed without error 00% 51701 - #17 Short offline Completed without error 00% 51533 - #18 Extended offline Completed without error 00% 51474 - #19 Short offline Completed without error 00% 51366 - #20 Short offline Completed without error 00% 51198 - #21 Short offline Completed without error 00% 51030 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thanks
