jolness1
- May 21, 2020
Hey all!
I got an alert from my TrueNAS scale box that one of the drives had two write errors.
Of course I panicked a bit. I do have 2 spare drives (running a 5 drive array with raidz2 so figure I can be ready immediately for a failure) and do have both a scheduled onsite and offsite backup but if I can avoid data loss, even better. I have it configured to run smart short Monday-Saturday and then a Long test weekly on sunday. All of the values look fine (besides just now noticing my power_on_hours and LifeTime in the smart self test don't match... I am unsure if that is typical or if I bought drives years ago that were more used than I thought? I swear they had next to 0 on them but hard to know now) (Edit: The number of total hours lines up nearly with my roughly 3 years of usage so.. I think they were new, wasa pretty sure but the lack of match concerned me)
So I shut down the machine after going through a troubleshooting guide I found here and noticed the cable from my HBA was seated by had more wiggle than I would like so I moved it to another cable and on boot, the error is gone.
I have a couple of questions (and am also open to any and all insight about this)
1) Is the scrub what would detect these errors? Or is it the smart test (the error came about 45 minutes after they both are scheduled to start)?
2) Does restarting normally make them go away? Would swapping to a new cable? It seems like it shouldn't but I will admit I have no clue.
3) What can I do to check to be sure the issue was actually a fluke?
I am running TrueNAS-SCALE-22.12.4.2, have been using this same build for 3ish years now and haven't ever had an issue like this. I believe I updated TrueNAS last week after the previous Sunday night scrub/long test so wondering if that is the cause? Doubtful again but just spitballing as I go here.
Apologies for a bit of a rant, did my best to organize my thoughts but still a little panicked. I shouldn't be, I have been cautious about data protection but just want to avoid any sort of unnecessary stress. Thanks in advance!
Edit: ran "zpool status" and notice it hasn't run since october 15th, threshold is 35 days so I am guessing it wasn't a scrub that turned this up. Running one manually to check now.
zpool status output:
Here is the smart output:
zpool status pool: Tank state: ONLINE scan: scrub repaired 0B in 01:59:05 with 0 errors on Sun Oct 15 01:59:07 2023 config: NAME STATE READ WRITE CKSUM Tank ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 088ae6a4-bf0b-11ea-94a7-0cc47a7040ac ONLINE 0 0 0 097971df-bf0b-11ea-94a7-0cc47a7040ac ONLINE 0 0 0 0990b440-bf0b-11ea-94a7-0cc47a7040ac ONLINE 0 0 0 09a9b329-bf0b-11ea-94a7-0cc47a7040ac ONLINE 0 0 0 09c25c50-bf0b-11ea-94a7-0cc47a7040ac ONLINE 0 0 0 errors: No known data errors
SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 130 130 054 Pre-fail Offline - 100 3 Spin_Up_Time 0x0007 167 167 024 Pre-fail Always - 409 (Average 380) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 50 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 096 096 000 Old_age Always - 28928 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 50 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1212 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1212 194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 17/40) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 12038 - # 2 Extended offline Completed without error 00% 12035 - # 3 Short offline Completed without error 00% 11990 - # 4 Short offline Completed without error 00% 11966 - # 5 Short offline Completed without error 00% 11942 - # 6 Short offline Completed without error 00% 11918 - # 7 Short offline Completed without error 00% 11894 - # 8 Short offline Completed without error 00% 11870 - # 9 Extended offline Completed without error 00% 11867 - #10 Short offline Completed without error 00% 11822 - #11 Short offline Completed without error 00% 11798 - #12 Short offline Completed without error 00% 11774 - #13 Short offline Completed without error 00% 11750 - #14 Short offline Completed without error 00% 11726 - #15 Short offline Completed without error 00% 11702 - #16 Extended offline Completed without error 00% 11698 - #17 Short offline Completed without error 00% 11653 - #18 Short offline Completed without error 00% 11629 - #19 Short offline Completed without error 00% 11605 - #20 Short offline Completed without error 00% 11581 - #21 Short offline Completed without error 00% 11557 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing
