S
sfranzis71
Guest
Short review of FN8.1-B4
Hello everybody,
I just tested FreeNAS8.1 Beta4 and went back to the 0.7.2 after half an hour.
Sorry, but I'm a bit disapointed from FreeNAS8. I really liked the 0.7 and will keep on using it. I hoope FreeNAS8 improves.
Greetings,
Stefan
Hello everybody,
- zpool import: importing an existig pool from the GUI did not work. 'zpool import -a -f' from the console worked, but the pool didn't show up in the GUI after that
- Diag/Logging: there is no Diag/Log menu item. How do I display my Logs in the GUI?
- GUI in general: the GUI is too complicated compared to the 0.7 versions. The 0.7.2 GUI is slim and simple.
Greetings,
Stefan
