RadicalSatisfaction!
- Jul 25, 2020
OK, guys, forgive my lack of familiarity with FreeNAS & server issues, this is my 1st NAS & I'm probably being way too cautious, but heat is a killer & I am always trying to keep temps down on the boxes I build, so here's my concern...
I dropped more than I probably should have on a motherboard for simply serving media to the entire house, as well as to provide a central location for work/documents we use at home for business. Eventually, we want to be able to utilize the server from our satellite/remote office locations as well, but for now I just want to be able to stream throughout the house... we have computers in every room these day (7).
The Supermicro A2SDi-H-TP4F has the embedded Intel Atom C3955 with a simple heat-sink attached; no fan... this seems wrong to me, despite everything I read telling me the Intel Atom's produce very little heat. Can that be true when streaming to a few rooms in the house at once, hi-res video, etc, i.e high workload?
On Supermicro's website, on the specifications page for this mobo, they show a couple of chassis' optimized for that motherboard, & 2 of the 3 images there, show a small fan attached to the heat-sinks. I called Supermicro & they didn't have any advice except to look at the same images I note above & try to figure it our myself (if you want to take a look, here is the link to the specs page, scroll to the bottom & click the links to the images of suggested chassis: https://www.supermicro.com/en/products/motherboard/A2SDi-H-TP4F?locale=en
Other images here: https://www.servethehome.com/supermicro-a2sdi-h-tp4f-review/
Anyone have a suggestion as to what fan I might use & how to attach? I have been planning to use the Fractal Design Node 804 case, but I have been thinking maybe I should use the Coolermaster Cosmos I have laying around here for this board if I can't find an applicable fan... It's a freakin' massive beast, I wanted to get rid of it but maybe it's a better idea? On that little 6.7" x 6.7" board, I could get a lot of airflow over that heat-sink without an attached fan in that specific case, & the more I am thinking about it, the better it sounds, as far as heat is concerned... I was trying to create a small footprint & keep it in my home office, but I think putting the server in a closet I have, centrally located in the house, might be a better solution. Low temps are FAR more important than a noisy box, especially if it is not anywhere near anyone. The tiny cases always concern me, so much heat generating electronics in a compact size seems to be asking for problems.
Has anyone ever used a small closet as a server room? Again, I am concerned about temps even in that closet. I designed a way to have a small window air-conditioner to vent into that room, but I was thinking that a small air conditioner like that might create too much condensation... any thoughts on that would be welcomed as well...
Thanks guys, always appreciate the knowledge & help offered here!
T.
T.
