Hello russnas,
I am learning more more about the smart attribute called Load Cycle Count that appears on the output of the smart data for my drives. I found this defintion on a forum post regarding Seagate Drives. Sorry I have not been able to figure out how to attach a link.
Load/Unload Cycle Count - Count of load/unload cycles
Number of cycles the head moved into landing zone position.
Here is the smart data result for one of my six hard drives.
[root@freenas] ~# smartctl -a -q noserial /dev/da0
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Seagate Desktop HDD.15
Device Model: ST4000DM000-1F2168
Firmware Version: CC52
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Sep 3 18:18:58 2013 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00)Offline data collection activity
was never started.
Self-test execution status: ( 0)The previous self-test routine completed
been run.
data collection 612) seconds.
capabilities 0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Error logging capability: (0x01)Error logging supported.
Short self-test routine
recommended polling time 1) minutes.
Extended self-test routine
recommended polling time 537) minutes.
Conveyance self-test routine
recommended polling time 2) minutes.
SCT capabilities: (0x1085)SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 106 100 006 Pre-fail Always - 11633592
3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 87
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 428731
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 643
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 88
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 048 045 Old_age Always - 34 (Min/Max 24/36)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 73
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 4547
194 Temperature_Celsius 0x0022 034 052 000 Old_age Always - 34 (0 17 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 452h+21m+53.538s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 330805526
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 418168784
SMART Error Log Version: 1
No Errors Logged
It seems that the load cycle count is high for the amount of power on hours I have, but I am not sure what to do about it.
I was hoping someone with better understanding would assist otherwise I will continue to search.
Thanks for replying
