SOLVED SCSI Status Errors
Hi all,
I built my first FreeNAS box about a month ago (been building it for a while, but the final version happened about then). It's based on a Supermicro X11SSM-F-O motherboard. There are four WD RED 4TB drives in the case, and four more in an external enclosure which is a Lenovo SA120 connected to an LSI SAS9200-8E.
This is an upgrade from an 8x3TB WD Red drives (which was running under a somewhat unstable ZFS Linux build), and the plan was to add those drives to the new array as soon as it seemed stable.
Which, after 3 weeks, it did. Completely stable, no errors anywhere, clean test scrubs, etc.
So I took four drives off the old array and plugged them into the SA120.
Immediately I started getting dozens of SCSI Status Errors and Aborted Commands. I'm talking several every minute, up to thousands per day.
So naturally I removed the "new" drives.... except the errors keep happening. Thousands a day.
I ran a scrub and, other than making the error rate jump to hundreds a minute, it found no errors at all.
From what I can tell, these are errors between the LSI card and the array, not actual drive issues. I've tried upgrading firmware, moving the card to a different slot, changing cables, etc. Nothing.
Naturally having my large data pool running with all these errors - real or not - seems bad. Does anyone have any ideas or suggestions?
Here's what the errors looks like; they are showing up on all the external drives (and none of the internal):
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): READ(10). CDB: 28 00 fe 6e 2b 30 00 00 b0 00 length 90112 SMID 952 terminated ioc 804b loginfo 31080000 scsi 0 state 0 xfer 0
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): CAM status: CCB request completed with an error
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): Retrying command
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): READ(10). CDB: 28 00 fe 6e 2a 30 00 01 00 00
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): CAM status: SCSI Status Error
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): SCSI status: Check Condition
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): SCSI sense: ABORTED COMMAND asc:47,3 (Information unit iuCRC error detected)
Jan  3 14:23:58 squirrel (da3:mps0:0:24:0): Retrying command (per sense data)
Just in case anyone else has this problem, I'll go ahead and admit my boneheadedness.
I've not used SAS controllers before. This card has two ports, and the enclose I a using also has two ports, so... I assumed you need to plug both into the enclosure. Mostly because that's how my 8-port eSATA multiplier worked.
Turns out the card has two ports so it can talk to two enclosures. The enclosure has two so it can be connected to two servers.
So basically my controller was telling the enclosure to do stuff and the enclosure was going "Dude you already said that."
Basically the solution was to remove one of the Mini SAS SFF-8088 cables.
It should work. The fact that it does is a minor bug. Each "port" is four lanes anyway, so what's four more? The protocol is not any more complex because of that.
Anyway, it doesn't matter in practical use, for most people.
I mean, it was working. There were just a lot of transport errors and aborted commands, but zero data loss. There does seem to have been some minor performance impact, but yeah, it wasn't really broken.
Just irritating and when you get that many errors, even non-fatal ones, you may as well fix it (:
